Ok, someone come pull this crank bolt out! lol
Old 03-09-2009, 06:23 PM
Deerhunter-Z28's Avatar
Default Ok, someone come pull this crank bolt out! lol
Never had this much trouble getting a crank bolt out and I've done A LOT of cam swaps, then again this is the first time I used an ARP. I didn't even torque it to spec, probably about 175ft lbs or so. Didn't use thread sealant either, just put it in as it came. Already broke a 1/2" breaker bar and an extension, give me some tips or come pull it out for $50.
Old 03-09-2009, 06:27 PM
LS1Aggie09's Avatar
call chuck norris
Old 03-09-2009, 08:06 PM
Bad Chad's Avatar
Is the motor still in the car? I just took a hammer and hit the break over bar...
Old 03-09-2009, 08:19 PM
jsteele90's Avatar
impact wrench
Old 03-09-2009, 08:28 PM
Yea thats what I'm gonna try next, just never had this much trouble before!
Old 03-09-2009, 08:47 PM
10 Second Fun Car
jlrz28's Avatar
Cheater pipe and feet on the wall is how I got mine out....
Old 03-09-2009, 09:40 PM
TATER's Avatar
Anti-Seize is your friend on the next bolt. Get a bottle of propane, or better yet, mapp gas at your local advance auto etc. Heat the end of the bolt as hot as you can (if you can get it cherry, then awesome), take the heat away, smack it as hard as you can with a hammer, drip some oil on it (or stick an unscented piece of wax all around it) then impact it. out it will come. A combination of rust and no high pressure lube on the threads before install is probably what got ya.
Old 03-09-2009, 09:46 PM
AgFormula02's Avatar
Breaker bar against floor, turn the key
Old 03-09-2009, 09:55 PM
ThunderZ28's Avatar
Impact gun is how I have done it...
you need a beefy one tho..
Old 03-09-2009, 09:56 PM
89camaro's Avatar
Originally Posted by jsteele90
impact wrench
x2 impact is the way to go
Old 03-09-2009, 10:21 PM
7420NW7TH's Avatar
3 ft long breaker bar. Go buy one at Sears.
If you can't get it with that you are a *****. j/k
Old 03-09-2009, 10:45 PM
306 That Could's Avatar
Still cant get it out???
Old 03-09-2009, 10:47 PM
INVISIBLEZ's Avatar
AJ I have a badass 1/2" drive impact if you need it. It had helped me out in these situations quite a few times.
Old 03-09-2009, 11:16 PM
kennyxg's Avatar
If you don't get it out by tommorrow pm me, pretty sure I can get it out.
Old 03-09-2009, 11:50 PM
Gonna try again tomorrow guys, just stumped me this time cause this is the first time I have had this much trouble. I would try an impact, but I don't have air tools, going to be my next investment now! lol
Old 03-10-2009, 12:54 AM
flatblackz's Avatar
dont buy the breaker bar from sears you have one attached to you jack, use the handle on a 1/2" breaker bar. thats how i got Mike96z crank bolt out.
Old 03-10-2009, 12:56 AM
flatblackz's Avatar
that will be $25 via paypal to flatblackz@yahoo.com lol j/k
Old 03-10-2009, 02:00 AM
I8ASaleen's Avatar
Get a good 1/2" impact wrench with at least 500ft/lbs. in reverse and it should come out.
Old 03-10-2009, 04:43 AM
$O$OE's Avatar
I just had a buddies who's crank bolt came off at a parking lot after some freeway runs...dont know how-T-F that happened but it did..
Old 03-10-2009, 09:10 AM
TWS
TWS's Avatar
Voting for Impact Wrench. When Aster was preparing for his procharger install, we pulled his car in my garage and both got on the breaker bar. With both of us pulling we just twisted my 1/2" extension completely 360* and it snapped off in the socket. He took it down the street to his neighbor and hit it with the impact... success.
