Check Engine Ligth OBD II wont read car's comp
Old 03-30-2010, 08:04 PM
01PewterMadre's Avatar
Exclamation Check Engine Ligth OBD II wont read car's comp
My check engine light came on and when I tried to use a code scanner I could not get get the scanner to read the car's computer. My dad said it could be a blown fuse. I lost my repair manual so I was hoping you guys could tell me which fuse might have gone out. Please help out this noob
i need the name of the fuse and where it is located on the car
thanks for the help
Old 03-30-2010, 08:52 PM
mitchntx's Avatar
The port needs 12V (on P16 IIRC).
Its a blown fuse behind the cover on the driver's side.
Old 03-30-2010, 09:02 PM
OUTLAWZ RACING's Avatar
The cig lighter will cause that also. check the fuse.
Old 03-30-2010, 09:22 PM
texas94z's Avatar
its the cig lighter.
Old 03-31-2010, 11:40 AM
69gto96z's Avatar
x2 on this one
Old 03-31-2010, 11:52 AM
THE SHOP's Avatar
Fuse number 11, its a 25 amp, inside drivers side dash area, lmk what your check engine code is.
Old 03-31-2010, 02:28 PM
00pooterSS's Avatar
X3, most commonly this is the issue. Unless your scanner does not have the proper software to read that particular vehicle, in which case you can use Global OBD2 to retrive the code, let us know the code....
Old 03-31-2010, 04:07 PM
chrysler kid's Avatar
Originally Posted by 69gto96z
x2 on this one
x3 my formula had the exact same problem and a new cigg lighter fuse fixed it
Old 03-31-2010, 05:37 PM
winger4800's Avatar
X1000 lol Check your fuses and go from there...what kind of scanner btw??? 5% chance it may be due to a cheap scanner..(even harbor freight sells scanners...now thats SCARY!!!)
Old 03-31-2010, 08:11 PM
It could be that I have a crappy scanner but the guy at autozone also checked it with their scanner.
Old 03-31-2010, 08:35 PM
THE SHOP's Avatar
I said the fuse number...
Old 03-31-2010, 09:26 PM
Thanks for the help guys. You guys were right. It was the cig lightr fuse. The guy at autozone didn't tell me the code number but he said it was massive clutch failure.
This would make sense since my clutch is about to go out. Its really soft and the gears sometimes grind when I shift (very mild grinding barely audible)
Does having a worn out clutch hurt the tranny? I figure it would but I'm an m6 noob so please be gentle with your response.
Since the subject has now turned to clutches do any of you guys recommend a specific brand (daily driving)
Thanks
Old 03-31-2010, 09:56 PM
00pooterSS's Avatar
If it is starting to grind its eating the transmission yes.
I know several people that have had good luck with the Ram clutches in LS1 cars and they aren't too expensive.
Old 03-31-2010, 10:08 PM
winger4800's Avatar
RAM is terrible but more important they have worse customer service. I wont go into too much detail but mine has been terrible since 2,000 miles and will be going with a spec. I have a friend that had the same issue and the fingers on the pressure plate were bent and Rams customer service didnt believe him so he sent it to them in a spec box lol....GO WITH SPEC....thats what i'm buying and also upgrade your hydraulics!
Old 04-01-2010, 08:31 AM
00pooterSS's Avatar
Hmmm thats odd I had the opposite results, personally have taken Spec clutches and replaced them with Ram's because the Spec's had issues..... Did not know about Ram's cust service though. But also you say they had bad customer service but sent him a new clutch?? Sounds like good cust service
The cars I have put Ram's in get dumped at 6-7 thousand RPM on slicks and have lasted a long time...
