Fuel injectors keep popping out of the fuel rail
Old 06-03-2010, 11:16 PM
Slash8915's Avatar
Default Fuel injectors keep popping out of the fuel rail
Here for the past month or so, at random times my fuel injectors will come loose from the top, so that the o-ring is just out of the fuel rail, and fuel will spew everywhere. I can always smell it, so I pull over, get out my tools and reseat my fuel rail. It happens to any random injector, and happens about once a week. I have speed inc. fuel rails, and ls6 intake, and stock ls1 fuel injectors.
I posted this in the fueling & injectors section, but the conclusion there was that my intake was an ls2. I'm 99.9% sure it's an ls6, so I figured I'd post here to see what you guys think it might be.
Old 06-03-2010, 11:38 PM
waterbug1999's Avatar
if your bolts are tight, then I dont see how seeing it sandwiches them into the intake.
Old 06-03-2010, 11:56 PM
Austin Auflick's Avatar
you have to have not used the mounting brackets. That's the only possible explaination. They're little "L" shaped brackets that bolt to the side of the rail and to the intake manifold.
Old 06-04-2010, 12:00 AM
402GOAT's Avatar
You may need spacers like you do on fast intakes. If the injector isn't seated in the intake completely when completely seated in the rail you need spacers
Old 06-04-2010, 12:23 AM
whitehooptie's Avatar
You need to get it fixed. Had a friend's 94 Cobra burn to the ground with the exact same problem. He was too lazy to fix it.
Old 06-04-2010, 07:47 AM
Slash8915's Avatar
I'm definitely using the mounting brackets. i was wondering if i got some 30#+ injectors if that would fix it.
Old 06-04-2010, 07:57 AM
Slash8915's Avatar
hmm... well the guy i bought the fuel rails from said he used them on his fast intake for a few passes at the track. Could that have something to do with it?
Old 06-04-2010, 08:20 AM
red281gt's Avatar
Had this same issue with my blown 2v one day , one of the orings was fucken , kinda chewd up, check the orings if not replace it with some ne GM ones or get the ones off old stock injectors if u have some
Old 06-04-2010, 08:27 AM
Slash8915's Avatar
I've replaced the o-rings already. That's what i initially thought it was. Guess it wasn't...
Old 06-04-2010, 09:02 AM
Morbid's Avatar
Have you tried putting the stock fuel rails back on to see if the issue persists? Quality controls does let a few bad ones slip by.
Old 06-04-2010, 09:22 AM
LS1TECH & Trucks Sponsor
Scoggin Dickey's Avatar
I don't understand how this is possible if the fuel rail is securely bolted down. Is the fuel rail actually coming up off the injector, or when it is bolted down is the injector too short so that when fully seated in the intake it can come out of the rail?
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old 06-04-2010, 01:09 PM
Slash8915's Avatar
I have the fuel rails bolted down to the manifold via the brackets. It's only one injector at a time when it happens. I smell fuel, pull over and take a look. The injector is always JUST past the top o-ring. I mean, the o-ring isn't even all the way out of the fuel rail, it's just not all the way in.
Old 06-04-2010, 01:23 PM
CarsandWomen's Avatar
how long were the rails on the car before this started happening? something def aint right, post a pic of the rails and intake
Old 06-04-2010, 02:13 PM
Slash8915's Avatar
they were on there for about a month or so. i'll go get some pics with my phone right now.
Old 06-04-2010, 02:37 PM
Slash8915's Avatar
Don't know if these will help, but...
Attached Thumbnails Fuel injectors keep popping out of the fuel rail-i.jpg   Fuel injectors keep popping out of the fuel rail-o.jpg   Fuel injectors keep popping out of the fuel rail-t.jpg   Fuel injectors keep popping out of the fuel rail-u.jpg   Fuel injectors keep popping out of the fuel rail-y.jpg
Old 06-04-2010, 04:30 PM
TT-TECH Veteran
Inspector12's Avatar
Those are the Proven products fuel rails not Speed inc. rails. Your problem is spacing. Either the mounting brackets are flexing or they are not spaced correctly. If the fasteners are not comming loose there is no other explanation and with that set up I am with the other guy who recomended you stick the stock rails back on there as you don't have a real need for them other than for looks. GL.
Old 06-04-2010, 05:02 PM
Slash8915's Avatar
I gave my stock rails away when I got these... Is there a way to fix the problem with THESE rails?
Old 06-04-2010, 05:43 PM
Modify the brackets to hold the rail down tighter. Either the rail is coming up or the injector is going down, and that is not acceptable. They have to be bolted down tight where there is not enough play for an injector to come out. I would quite simply modify the brackets or make new ones.
__________________
Old 06-04-2010, 05:48 PM
LS1Tech Sponsor
Beau@SDPC's Avatar
I had a problem with those rails before. They are Prof Products rails. The weak brackets are the problem. Like Jesse said.
These work better.
http://scorpionperformance.com/newsi...uelrailsMD.gif
Old 06-05-2010, 06:38 PM
1c62nv's Avatar
These work better.
You have a PM John
Quick Reply: Fuel injectors keep popping out of the fuel rail
