headlights open wen i lock my ws6?
Sounds like a BCM issue maybe....
Somewhere in there, the controller is getting a quick signal to turn on the headlights. Give me a minute and I'll see if I can find a schematic.
x2 - The stock nylon gears with some worn teeth can cause them to do strange things, but you'd usually hear some horrible grinding that you couldn't miss. Also check that the connectors on the harness going to the lights/motors are clean and well seated.
yea once it closes it starts making some weird noise its kinna annoying .. so ya kno were i can get the new gears for the lil motor of the headlight?
Just go up to autozone and they can order you a new motor. I would replace both of them with new motors not just the gears. I think it was 75 for the passenger side and 125 for the drivers side. They will give you 25 cash back when you bring the broken parts back as a core. I saw they are using nut and bolt to renforce the gears instead of just the glue or poxy. GL
