So freaking tired of leaking ttops!!
Well, my ttops leak. all over my leg, arm, and my seat when im not in it creating a lake when i get into my car. its not toooo bad but when its just right it will, drip............ drip.......... drip.......... and its ANNOYING!!!! i carry a towel in my car at all times.. is there a fix for this or ne thing? btw hope everyone made it to work/home safely so far this week
Most likely it is the weather stripping.
Our cars (mine is a 2002 as well) are 8 years old and with out proper care for them and conditioning, they will deteriorate.
If you do end up getting new weather stripping, be sure to condition them after every wash. That will help prolong the life of them and keep them looking new.
Mine leaks at all the weather stripping beginning/end points, right on the crack where they meet.
I was thinking of putting a thin bead of RTV or sealant or something, its rather annoying =/
Buy a little tub of vasaline and rub it on your weather stripping. My driver side will let a but of water in at both the front and rear meeting points of the t top, but the vasaline will soak into the rubber and fatten or swell it up a bit. Depending on how bad the leak is it will either help or fix it. Makes the windows a bit messy but it's worth not having your pant leg look like you pissed your pocket.
Okay so, I have a question... I have had weather stripping replaced on my car, so the t tops dont leak anymore.. YET when it rains the passenger side floor board has water on it ( behind the seat ).... Like I have sat in the back seat of the car while it rained just to see where it was coming from and i have NO idea.. Water just appears, is bs!!! Anyone have any ideas?
dude you read my mind i was just about to post this for my 2001 camaro today lmao. mines is a small leak but i freaking hate it. i wanna change the weather stripping but im scared of the bill lol
looks like im the only one without any leaks, knock on wood. today was definitely the day to test it too, i went outside at first break around 9 and it was f'n pouring, i stood under the covered walkway that goes around my building to smoke and i looked like i went wading knee deep in a lake.
im jealous of you guys with no leaks!! i think the vaseline will work ill try that this weekend maybe. and yea i wonder how much the bill is to replace it all, and if it will even help....
If you do decide to replace the weather stripping, I would probably get it from gmpartsdirect. Seems to be quite a bit cheaper than a dealership as with anything. Would still be pricey I would assume. But post back up after you vaseline that bad boy up. Im pretty sure you will be happy with it. I usually cake it on there, let it sit for a few days, then wipe off the excess.
I got the same thing going, on, my relativly low mile CETA, that has never had any leaks or even t-top whistles, the rear passenger floorborad jsut started filling with water this last week.
