Soft clutch pedal
Old 11-09-2010, 07:29 PM
Ballerado's Avatar
Default Soft clutch pedal
Ok so yet again another mushy pedal thread, but here's the kicker. It's only happening when the car is cold. Also, the longer it sits the worse it is. I just went through a **** load of clutch/tranny drama. But, to give the meat and potatoes of it all, I've got a new spec 2+ (750 miles on it) new rebuilt t56 (500 miles on it) and new slave cylinder (500 miles) only thing that isn't new is the master cylinder. It's a McLeod adjustable and when I swapped my clutch I replaced the o ring and rubber cup on it. I never had issues before. I'm just stumped on what it could be. It seems like once the car is warmed up and I've gone a few miles it's ok. I really don't know, ANY help would be just fantastic.
Old 11-09-2010, 08:14 PM
westtexasbuff's Avatar
What are you doing to bleed it?
Old 11-09-2010, 08:23 PM
Ballerado's Avatar
Mity vac. And right after for at least a week I didn't have any issues
Old 11-09-2010, 09:46 PM
JoeKnowsBaseball's Avatar
Obviously you checked to make sure of any clutch fluid leaks and that it's full...
You could have a random bubble in the slave. I did my gf's clutch in her firebird about a year ago and had to let the clutch gravity bleed for about 4 hours till it was good.
When the pedal gets soft, is it hard to get the tranny in gear?
Old 11-09-2010, 10:35 PM
Ballerado's Avatar
I haven't found any leaks and the fluid level isn't dropping any. Getting into gear becomes more firm for 1st and reverse than anything else.
Old 11-10-2010, 07:06 AM
8 Sec Tuner
Mike TexaSS's Avatar
Buy a Tick master..... Shift and enjoy!
Old 11-10-2010, 11:23 AM
Ballerado's Avatar
Any info on how that will solve my issue?
Old 11-10-2010, 12:15 PM
Tick masters flow more fluid than stock ones. More fluid helps clutch engagement. Also lowers fluid temps.
That, or try the drill mod. What year master is it? I think the early ones were the bad ones... 01-02s were the good ones.
Old 11-10-2010, 02:26 PM
Ballerado's Avatar
I've got a McLeod master. And the braided line has the drill mod.
Quick Reply: Soft clutch pedal
