LMR (Late Model Racecraft) Wideband o2 Sensor Location?
Old 11-15-2011, 06:03 PM
2TR
2TR's Avatar
Lightbulb LMR (Late Model Racecraft) Wideband o2 Sensor Location?
I see a pipe welded to a jackstand with an o2 sensor portruding out the side which is inserted into the tailpipe of vehicle.
Anyone else seen or used o2 sensor in pipe sticking out rear exhaust location?
I always thought it normal procedure to remove (1) front o2 sensor
or
Install seperate dedicated o2 bung before catyltic converter for dyno testing
Photo:
NOTE: NOT A CALLOUT. MY QUESTION IS FOR EDUCATIONAL PURPOSES!
In my opinion LMR is the king when it comes to LSx tuning.
Photo taken from the video here:
https://ls1tech.com/forums/texas-mem...racecraft.html
Old 11-15-2011, 06:21 PM
onspeed's Avatar
pretty sure that's a normal procedure for dyno tuning.
It might read a little leaner on cars with catalytic converters.. but the tuner could just compensate for that difference.
I know Innovate sells a handheld WBO2 unit with a tail pipe clamp attachment.
Old 11-15-2011, 06:34 PM
2TR
2TR's Avatar
The folks on Hp Tuners forum in genereal typically frown on a tailpipe clamp o2 sensor.
This looks like a custom made tailpipe setup with the same premise.
Again it obviously works (LMR ain't no second hand shop)!
I understand as a general rule you would have to compensate approximatley +.2 AFR if the vehicle has catalytic converters.
Just wondering what LMR's among others thoughts were...
Old 11-15-2011, 06:42 PM
OUTLAWZ RACING's Avatar
had my car tuned they same way but I had a widband in the down pipe also. the reading where very close widband was 11.5, tail pipe was 11.7.
Old 11-15-2011, 06:44 PM
Turbo_Stang's Avatar
Easier Target/Realistic AFR. EGT's.Not to mention different gases and location can damage sensors.Keep in mind calibration and EGT's
Old 11-15-2011, 06:57 PM
2TR
2TR's Avatar
Originally Posted by 8urls1
Easier Target/Realistic AFR. EGT's. Not to mention different gases and location can damage sensors. Keep in mind calibration and EGT's
Those are DAMN good points!
Old 11-17-2011, 10:38 AM
Worm Boy's Avatar
Yes, on most street applications(500hp) we use the wideband in the tailpipe. For forced induction/nitrous cars making big power, we use one after the headers collector and another out the tailpipe just to be safe. As always, we road test vehicles to check A/F readings. Hope that helps.
Old 11-18-2011, 01:28 AM
winters97gt's Avatar
The way it should be done. Not every shop around does that.
Quick Reply: LMR (Late Model Racecraft) Wideband o2 Sensor Location?
