can someone help me bypass my vats code...
Old 12-17-2011, 05:14 PM
domestiks's Avatar
Default can someone help me bypass my vats code...
not sure what wires to splice and solder...
saw a video on you tube where they do it with resistors, but still stumpped
thanks for any help
Old 12-17-2011, 07:17 PM
ramairracer's Avatar
where are you located
Old 12-18-2011, 01:46 PM
domestiks's Avatar
west dallas off 30 & loop 12
Old 12-19-2011, 08:21 AM
2001AntiVenom's Avatar
Pull the bolster off under the steering wheel. There is gonna be a 2 wire connector that is white wires I beleive with a orange sleeve around both of them. After u know what resistors u need then u unplug them wires and put the resistors to the wires that go toward the firewall. Not the column side
Old 12-19-2011, 10:06 AM
GreatWhiteZ28's Avatar
Shbox.com had a nice clear diragram on it..
Old 12-20-2011, 05:50 PM
domestiks's Avatar
ok found the orange sleeve with 2 white wires now to look for an ohm reader...
Old 12-21-2011, 09:35 AM
aquariussuperman's Avatar
I did this last night and the security light is now gone. Wired in 2 resistors in series to get the correct resistance and no more light! Thank you LS1tech community!
Make sure you put the resistance on the correct side of the wires! The physical configuration works if you hold the paper upside down.
http://shbox.com/1/vats_bypass.jpg
Old 12-21-2011, 10:28 AM
03Sssnake's Avatar
I had to do this with C5Z05, the two contacts inside the ignition cylinder that read the pellet in the key broke. Worked like a champ!!
Old 12-21-2011, 04:06 PM
cambirdracing's Avatar
Anybody ever had their car start with the connector unplugged? I got a resistor for my 94, put it in and the security light was still on. Took it off, left it unplugged and it still started. Security light stays on about 90% of the time.
Old 12-21-2011, 08:08 PM
domestiks's Avatar
yup works good i just started mine used 2 resistors a 1.5k and 330 thanks guys
Old 12-21-2011, 10:11 PM
mitchntx's Avatar
We use these in our road race cars.
http://www.bakerelectronix.com/products_vats/
We strip the columns and remove the key start altogether.
Start using a momentary switch on the dash.
Old 12-21-2011, 10:33 PM
domestiks's Avatar
hey guys it didn't start it cranked and i thought it would start. but after i put gas in it all it would do is crank... the fuel rail didn't have fuel, i left the key forward hoping it would build fuel pressure... also i had last started about 8 months ago...
any advice or help would be awesome
Old 12-22-2011, 10:06 AM
03Sssnake's Avatar
Did you measure resistance properly with digital multimeter (Set your meter to the 20k ohm setting)? How did you read the resistance of the pellet in the key( one lead on each side of the pellet)? Verify your 1.5ohm reading, its a tad outside of ohm values GM used, although I believe there is some room for slight variance. What type of resistor did you buy? I had to try several, a 7.5ohm (1/2 watt resistor) ended up being the ticket for me.
ohm values for GM Passkey
1覧覧 0.402
2覧覧 0.523
3覧覧 0.681
4覧覧-0.887
5覧覧-1.130
6覧覧-1.470
7覧覧-1.870
8覧覧-2.370
9覧覧-3.010
10覧覧3.740
11覧覧4.750
12覧覧6.040
13覧覧7.500
14覧覧9.530
15覧覧11.801
Quick Reply: can someone help me bypass my vats code...
