05 Gto won't hold charge abs inop trac control and brake light on?
Hi everyone, i have a 05 Gto with 70K iles on it. It will not hold a charge at all. Installed a brand new battery drove it around for about an hour and after turning it off it will not start w/o jump. The abs inop,traction control light and brake light are all on kinda making me think the alternater possibly. Any ideas or feedback would be heghly appreciated, thanks
Mario
Mario
sounds like a alternator problem, there is a regulator in the alternator that might not be working like it is suppossed to. Take an volt meter and test the alternator if it does not register 13 1/2 volts it is not charging. Hopefully this helps I had the same problem with my 02 camaro Z28 Ls1
