ls6 oil pump
ls6 oil pump
i had a question, i have been wanting to get a ls6 oil pump because i heard they are better that the stock ls1 oil pump. but then someone else told me the 01-02 ls1 oil pump (which i have) is the same thing as a ls6 oil pump? can someone with the knowledge help out, i dont wanna spend the money on a oil pump if i dont have too, thanks.
Any chance you found out any information?
Wondering which oil pump i need for my LQ9, would be great if you could share what you found. Not saying i could not call myself of course
Are you doing a cam swap? Why do you want a new oil pump? My stock 02 oil pump was working great (50 psi at a warm idle) at 136,000 miles before my cam. My oil pressure has ever since been lower with the SLP oil pump (Melling 10296).
Also, im pretty sure they are not the same.
If your oil pressure is fine right now no need to do all that work for nothing.. But if it will ease your mind get a tsp ls6 pump.
While your in there upgrade that timing chain.
