Will I pass Inspection
Gents,
I need to put some miles on my new block and was wondering if I would pass inspection with the these DTC codes P0103 MASS Air Flow High Frenquesncy and P1637 Generator L. Terminal Circuit. There is no SES light? It also has two incomplete on once per trip test, but my car is allowed two of those since it's a 2000. Any help greatly appreciated...
Vehicle: 2000 Ws-6
DTC's Readiness State:
P0103 MAF
P1637 Generator L Terminal Circuit
Continuous Tests:
All complete
Once per Trip tests:
Catalyst Complete
Heated Catalyst N/A
EVAP Incomplete
Secondary Air System Complete
A/C System N/A
Oxygen sensor Incomplete
Oxygen Sensor Heater Complete
EGR System Complete
Vehicle: 2000 Ws-6
P0103 MAF
Continuous Tests:
All complete
Catalyst Complete
Heated Catalyst N/A
EVAP Incomplete
A/C System N/A
EGR System Complete
You will fail with EVAP Incomplete. It needs more miles under varying driving conditions. Oxygen sensors also need to be ready. Are you running catless? You'll need O2 simulators if you are. I just went through this on two different cars that had batteries disconnected for awhile. It takes awhile for the emissions system to reset.
Second it will NOT pass if you have ANY check engine codes, also will not pass if you have any tests not completed. They have really gotten hard core on that lately to prevent people from getting around issues. Dont waste your time and money if you have codes and the pcm isnt ready. If you need to drive the car around legally to finish tuning it and getting the bugs worked out you can go get a temp tag from the dmv for around 30 bucks and its good for a month and totally legal to drive. Just need insurance on the car and boom no inspection sticker needed.
Hope that helps.
Wrong, well in austin anyway. If it is a emmission county yes you get charged for the inspection if you pass or not. Be honest think about that from a business standpoint? How would you stay in business if you didnt charge people for work performed, depended on if the customer took care of their responsibilities?
Hope that helps.
Hope that helps.
Same topic but different question. Say you have tint on your windows that won't pass inspection. Can I just roll them down and pull the fuse and tell them my windows won't roll up and I havent found the cause yet. They still are able to pass you right?
Ahh ok. So I was right just had it backwards in a way. Basically they won't charge you twice.
I had to take my DD to two different places cause my tail light lenses were broken at the bottom, the law says no light can shine through and there wasnt any , but the first inspector said he would fail it, the second one said no problem.
well i know i have a check engine light on and it passed inspection. tint there is a few places around here that will pass it. i know a guy i work with just got his passed after getting a ticket for it being to dark.
If you passed inspection with a check engine light on you are in a non emission testing county. As long as they don't do emissions they don't car about the light. Just that it passes safety stuff.
