Grinding noise while trying to start up
I go to crank it and its a big GRINDDDDD!!!!! at first it turned the motor over but didnt turn on.... now its just grinding.... I have switched 3 starters already so its not the strarter... the flywheel looks good from what i can see... what can be causing it to grind? I just pulled the trans out and everything looks good.....
Any help is greatly appreciated
pulled bellhousing and clutch off.... Looks like the clutch was not installed correctly .... cause the trans was a B**** to seperate from the bellhousing..... and the "new Pilot Bearing" is trashed..... Im assuming my helper was not aware how to install a clutch.....But took the starter to Vato Zone and exchanged it for a new one... time for attempt 2
