SO how soon can i spray ???
I just got the new c6 and its slow!!!!!!!!!!!!!!!!!!!
How much soon can i spray it and how much can it take thru the automatic??
I dont want to have to go to a th350 or th400.. I have destroyed so many trannies in both my other cars and im using a th350 in one and getting a th400 for the other...
Originally Posted by Ell Ess Won
The C6 is slow? Makes you sound like a badass. *rolls eyes*
huh?? it is slow for now..my little 4 cylinder made over 500hp and my 6 cylinder run high 9s on street tires..Im not trying to be a badass...i just have the need for speed
Originally Posted by Inspector12
Duy I think you can spray a 150 shot fairly easy as far as the trany holding up that is just a hit and miss thing.
Jeff
Jeff
damn i hate having to to go thru auto trannies, but i dont like manuals for drag racing..Is 150 safe for that tranny???
((((((Administrator))))))
Peace,
Craig.
Originally Posted by jlrz28
You dont always have to put a th350 or a th400 transmission in if it breaks. I think their some other alternatives.
i am pretty sure a 150 shot would be fine for a stock application... if anything just put a better tranny cooler on the car.
and Ell Ess won, i wouldnt talk much **** to Duy LOL... he considers the c6 slow due to his supra running 9.9's in full street trim and his bad *** 240
his rides are on www.visionboy.com - might want to check it out before you speak out of your *** again
That's great that he has some sick rides, but a stock C6 is still far from "slow"!
Duy you should have bought mine damn it
This is what I would recommend you do
Step 1: 2800-3200 stall
Step2: Gears the 3.15's blow and make the car feel like ****. Upgrade to a built (hardend output shaft) 3.42 gear ratio. Dont want to spray off the line with a stock gear. (Ask MTI about that)
Step3: let her breath. Equip the C6 with C6 Kooks 1 7/8 headers w/X-pipe.
Step4: Equip a TNT (new desgin for the C6) kit 125-150 should be safe.
Step5: when that gets old slap a G1 cam and Stage2E heads
Friend with this setup:
3200 stall
3.15 gears (couldnt spray out of the hole)
dynotech headers LT's
TNt 150 shot
and DR's
rwhp: 462
Ran 10.98 @ 127
You run heads/cam setup with a 150shot ... You knocking on the door of single digit number passes.
I am putting down 440/400 with a heads/cam setup out of the built 3.42 gears.
My next step if I keep it will be TNT 150-175 shot.
Let me know if you have any other questions brotha
Cheers
G
3200 stall
TNt 150 shot
and DR's
rwhp: 462
Ran 10.98 @ 127
Cheers
G
LS1Tech Co-Founder
I think my stock C6 is slow too. They aren't much quicker (if any) than a stock f-body, especially from a stop.
Duy, did you at least buy the 6-speed automatic 2006 model? It has a paddle shifted 6-spd tranny. If not, return that POS and get either a manual or the A6.
(Ill find the link)
Do some research if you plan to mod it if you have the A6. Thats a whole different ball game.
