Anybody ever have this problem
Old 10-11-2005, 08:12 PM
1SICKhawk's Avatar
Default Anybody ever have this problem
Some annoying squeeks coming from the belt/pulleys...I did leak some antifreeze on the belt but i rinsed it with water and it quit for a few days..i've had the pulleys for months..everythings tightend up.....any thing else it could be? Open for suggestions.
Old 10-11-2005, 08:17 PM
FIREHAWK #07's Avatar
tensioner might be bad..... isnt it made of plastic?!?!?
Old 10-11-2005, 08:37 PM
1SICKhawk's Avatar
good hint
Old 10-11-2005, 09:33 PM
rumblebox's Avatar
a belt can look perfectly normal and still squeak, and nothing can fix it except changing the belt.
Old 10-11-2005, 09:56 PM
Figz Z28's Avatar
It might be your idler pulley. My car did the same thing a while back the bearing's go bad on them, you might want to pull it off and check it out before going out and buying a new one.
Old 10-11-2005, 10:39 PM
ls12000's Avatar
I had that same problem. Mine would squeak when i drove it and when the car would idle. couldnt stand the noise. I replaced the belt and problem solved
Old 10-11-2005, 10:48 PM
A_W_O_L's Avatar
If i was gonna play e-mechanic, i'd ask how many miles it had on it....and say that the water pump is about to start leaking worse (may take some time)...and have to be replaced. keep an eye on the coolant level.
Old 10-11-2005, 10:57 PM
rumblebox's Avatar
idlers dont squeak. they roar and grind. it's the belt.
Old 10-12-2005, 07:04 PM
chevy42083's Avatar
Try holding a bar of hand soap to the ribbed side of the belt while the car is idling. Try to hold the bar in the same place at the same angle till the belt has worn deeply into the soap - this way the entire rib will be coated, not just the very edge.
My truck always squeaked till I did this. It would go away INSTANTLY and sometimes came back when the belt was splashed with water in the rain. After awhile, it never came back.
Worth a try, right?
Oh yeah, be careful, and I take no responsibility for what you do to your hand.
Old 10-12-2005, 07:06 PM
Ell Ess Won's Avatar
I can hear my belt spinning but it's not really a squeek, I think its just an fbody thing.
Old 10-12-2005, 08:25 PM
T/A-Speedfreak's Avatar
I had the same problem. It turned out to be the alternator. Take your belt off and spin it to see if it makes noise.
