Is what a BFG DR looks like? Plus Nitto/BFG Comparison
Old 03-14-2006, 07:31 PM
TINKRD's Avatar
Default Is what a BFG DR looks like? Plus Nitto/BFG Comparison
Got them today from tirerack. When i ordered them i noticed they were listed as "BFG Drag Radial 2".
They were listed at $155.00 and they didnt have another BFG DR listed. Read the description and it was all the normal mumbo jumbo.
:dunno:
we'll see if they hook.
Oh plus the comparison on how Nitto's run narrow. :yup:
Old 03-14-2006, 07:38 PM
crAzy95Z28's Avatar
i got a set for 175$ bad *** deal.
they hook alot better than those nittos.
Old 03-14-2006, 07:42 PM
TINKRD's Avatar
:hmm:
:dunno:
From tirerack's website:
BFGoodrich g-Force T/A Drag Radial 2 (Competition)
The only change will be the tire's name on the sidewall. The g-Force T/A Drag Radial-2 will retain the Comp T/A Drag Radial's dimensions and proven asymmetric tread pattern, making it compatible with the original Comp T/A Drag Radial, allowing both tires to be paired together for use on the same axle. While the name change will take place gradually during the second and the third quarter of 2004, BFGoodrich plans to convert all sizes by the fourth quarter.
No matter whether you run the g-Force T/A Drag Radial-2 or Comp T/A Drag Radial, their radial construction combines the enhanced traction, superior handling and extended durability not normally associated with competitive bias-ply drag racing tires.
Old 03-14-2006, 07:44 PM
joeformula's Avatar
BFG renamed the BFG Drag Radial to the BFG G-Force Drag Radial. I Guess they changed the name back. And yeah they hook alot better the Nitto's!
Old 03-14-2006, 09:01 PM
mellowyellow's Avatar
Those look just like my 16" BFG DR's.. And yea they hook...
Old 03-14-2006, 09:07 PM
TINKRD's Avatar
just went and tested them out. 35 hit and 55 hit. spuns both times
oh well. Guess i'll just have to get used to it.
Old 03-14-2006, 09:25 PM
What kind of air pressure you have in them ?
Old 03-14-2006, 09:47 PM
2002C5COUPE's Avatar
those don't look anything like the BFG DR's i bought about a year ago. They look more like a mini van tire,
Old 03-14-2006, 09:49 PM
Well they should they go on his mini-van..
Old 03-14-2006, 11:05 PM
TINKRD's Avatar
15lbs
Old 03-14-2006, 11:25 PM
9 Sec. Club!!!
dan03mach's Avatar
Originally Posted by jaypee1217
15lbs
Get some VHT, do a burnout and launch it from a dig at the track.. They will hook..
Old 03-15-2006, 12:13 AM
BBADWS6's Avatar
Damn, those dont even look like the drag radials i remember, mabye they just changed the tread pattern. Either way you need a nice burnout to get them sticky.
Old 03-15-2006, 08:20 AM
WizeAss's Avatar
WHY NOT BUY ET STREETS?? THEY HOOK!!!
Old 03-15-2006, 08:43 AM
F1_SS's Avatar
Holy ****,your not hooking at 15lbs?
Lets run from a 20 roll.
Old 03-15-2006, 09:52 AM
joeformula's Avatar
You have to put a few miles on them first, about 50 or so. They'll hook better after that.
Old 03-15-2006, 09:59 AM
TINKRD's Avatar
too much naaaaawwwwzzzz
Old 03-15-2006, 11:13 AM
xfactor_pitbulls's Avatar
For sure, you need to get the grease and wax off of them. They will get better after a week or so. My nitto drags did the same thing.
Brandon
Old 03-15-2006, 12:19 PM
SiL3NtXWS6's Avatar
I have those tires and i can hook from a 40 punch @ ~600whp
275's too. Make sure they are HOT.
Old 03-15-2006, 12:22 PM
BC 01 SS's Avatar
that is the way the drag radials look now, and jp, how much beating of the fender well did you have to do, to make them fit?
TINKRD's Avatar
i guess i'll just have to heat them up before i go FRUM ROLL race anyone.
But i'm puttin down more then that
Quick Reply: Is what a BFG DR looks like? Plus Nitto/BFG Comparison
