Clutch woes
So its just hard to put it in 1st and reverse from neutral? It could be a problem with your slave but I would doubt it with only 18K on the car unless you've been giving it unholy hell nonstop!
Its pretty universal for the t-56's to have a slight problem from time to time going into those 2 gears. i've 2 6-speed ls1's and both have had that same minor problem of not wanting to go into 1st and reverse but they will after a quick retry
Originally Posted by SlowTA
i have ls1tech audio books on tape
How do you spot risk? How do you avoid risk and what makes it so risky?
Try having it bled first, if that doesn't fix it, then it's probably the slave. The same thing happened on the Z, and bleeding it fixed everything... for a little while at least.
Originally Posted by bluestreak98
soooo.....should I bleed the system? I live in an apt. complex so working on the car myself is pretty much out of the question, im going to have to try and take it somewhere regardless. Any ideas?
nah just jack it up on the bitch across the way's car
