RPM Motorsports.. "thanks"..
Just wanted to thank the guys again @RPM..
Jay did an awesome job with the install... Brian followed it up with the tune..
Had them install my Ported LS6 heads, new long tubes,wires,injectors, etc...
Prior to the install my car dynoed 377 @ the wheels.. Here is the dyno afterwards..
[IMG][/IMG]
Not too bad for my A4 with 3500 stall,323's & RPM4 cam...
What do you think?
Oh & lets not forget Brandon @ NixCylinders heads... He does an awesome port job "by hand"....
Thanks again..
[IMG][/IMG]
What do you think?
Thanks again..
[IMG][/IMG]
What do you think?
Thanks again..
[IMG][/IMG]
What do you think?
Thanks again..
Brandon
Originally Posted by mailman2000
shouldn't you pick up more than 23 horses with heads and LT's
Brandon
Originally Posted by dan03mach
It looks like your running out of fuel at the end.. You might want to get a bigger fuel pump soon..
Actually dan hes not....Brian tuned it to be a tad richer at peak torque and then leans it out for peak HP numbers.
Same way I tuned my car.....You should read up on that stuff. LS1's dont run out of fuel NA at 400 at the wheels.
When they were dumped (before heads) i dynoed @ 388 @ the wheels...
Truth be told... if i were to cut off my exhaust (back to the dumps) i would easily see 412-415.. on this car..
I think these are pretty good numbers on an A4...(4L60E)
I would also be willing to bet that mod 4 mod... there are not alot of A4 F-bod's @ or over 400 @ the wheels...
The heads are Stage 1, stock valved... hand ported... & flow nicely..
Thanks..
Just like we have done with ALL of the ARD threads, this one will be LOCKED. We will not have these non-sponsor threads pop up in here. Become a sponsor and you can have all the RPM stuff in here that you want.
