Front Brake COMBO
Front Brake COMBO
itz time for new pads/rotors.. any good combo suggestions??
im done with drilled/slotted rotors cuz they get too much hairline cracks... im almost certain that ill be getting HAWK HPS pads.. but any opinions??
for almost the same price you can get brembo blanks, and hawk hps pads, you can go to summit and get the SSBC rotor/hawk pad kit for around 340.00 then you got an extra 100.00 to spend on some stainless steel brake lines....
just a thought... ill be getting teh SSBC kit next week
Originally Posted by DONAIMIAN
brembo rotors and hawk pads is what I would recomend. Along with some good brake fluid (a full system flush) and youll be fine. You can skip the stainless brake lines.
so you cant notice a difference in ss lines over stock? why is it that you prefer brembo blanks over ssbc's slotted rotors?
trey
You stock lines are stainless to begin with. Most of the difference noticed in the pedal after the lines is becuase of the fact that you bled the system and it now has fresh fluid.
Brembo's are heavier rotors, they have more mass...more mass that the heat can dissipate into.
sweet bro, preciate teh info.
Originally Posted by PewterY2KZ28
I am running the Eradispeeds with a Napa pad... Both have many miles... Need to get the rotors re-surfaced soon.. & i'll probably go with the Hawk's...
You cant get slotted and drilled rotors turned
