Need Help Asap
Old 09-29-2006, 04:01 PM
99TA04's Avatar
Default Need Help Asap
I ran out of gas so i called my friend to bring me some gas and some we put about 3 gallons and the car still won't start and info would help.
Old 09-29-2006, 04:06 PM
A-Bomb's Avatar
i would try unplugging the battery and let it sit for a few minutes and then hook the battery back up. Let the car reset itself and see what happens. it's worth a shot.
Old 09-29-2006, 04:07 PM
99TA04's Avatar
Alright will try that but anymore info will help not at the car right now. Thanks A-Bomb
Old 09-29-2006, 04:14 PM
monicaz28's Avatar
Does it even try to turn over or is it completely dead?
Old 09-29-2006, 04:22 PM
FatZ28's Avatar
There might be air in the line.....Hopefully you didnt burn the fuel pump up.
Old 09-29-2006, 05:00 PM
99TA04's Avatar
it tries to kick over it just won't
Old 09-29-2006, 05:03 PM
Brandon Boomhauer's Avatar
turn the key on for a minute before you try to fire
let the pump push some fuel
or check the fuel pump fuse, it might have blwon
Old 09-29-2006, 06:07 PM
SILVER SS 00's Avatar
if not get under the car where the gas tank is hit it with a hammer or some kind of metal about 3 times then start it.if it starts is the fuel pump
Old 09-29-2006, 06:39 PM
camarossdn's Avatar
Ya bang it while you are trying to crank it. If it starts up then you shorted the pump.
Old 09-29-2006, 09:16 PM
99TA04's Avatar
I banged on it and still nothing so i guess its time for a new fuel pump
Old 09-30-2006, 12:41 AM
Josh McGrath's Avatar
most likely you burned it up... they are gas cooled (which is kinda ghey) so no gas means too much heat and bam
Go with a walbroro, its cheaper anyhow
Old 09-30-2006, 01:05 AM
Pwebbz28's Avatar
If you did burn up the pump and your car is a 98 get a cheap walbro. If it is a 99+ get a Racetronix Walbro. The install is MUCH easier than trying to cut up everything. It is the same pump but racetronix puts a different shell on it to make it fit like factory. You get something better than that cheap *** rubber hose to connect it to the fuel line.
Old 09-30-2006, 10:54 PM
99TA04's Avatar
Thanks guys going to buy a new fuel pump probablt wednesday
Old 10-01-2006, 12:23 AM
tylerdurden's Avatar
That sucks man those are a pain in the *** to work on the ground. Postive side is that with an upgraded pump, Nitrous might be around the corner. lol
Old 10-01-2006, 12:27 AM
will350wax's Avatar
turn the key on and check the schrader (sp) valve on the fuel rail. that way you know if you are getting fuel pressure or not for sure.
