My car isn't running right..Any suggestions?
it is on low boost
It feels like it's kind of missing and idle quality is not good. Does anyone know what this might be caused by? It's hard to start in the morning times as well.
Any advise will help.
Originally Posted by ckyconan2003
possibly the opti, have you tried going above idle?
P.S: If the car isnt running right, then try running it left!!!! BA ZING!!!
Moderator
Problem lies in not having a solid roller stroker with a hidden direct port set up. GW2 is just saying it wants to skate from a 80 punch.
switch oils? switch gas you use, maybe add a oil additive like Lucas. What I did one time, is just seafoam the hell out of it, and change the oil, oil and fuel filters. It was right as rain after that. THink of it as a colon cleanse for your car.
Originally Posted by Inspector12
O2's baby. They alway seem to cause just these type of problems. I am just guessing although a Tech 2 will most assuredly tell you and if not will let you eliminate a lot of possibilities etc...
Originally Posted by IconAutoSports
Check the clearance of the Pflugerbinders located underneath the Penwick Union Cylinder (passenger side fenderwell) should be .030"-.038". Re-shim as needed.
If you've had the intake off, recheck the torque in all the bolts...
Kinda sounds familiar.....
