Header bolts....
Header bolts....
i cant seem to get my pacesetter headers on because the manifold bolts im using are giving me clearance issues. Is this normal or can i get bolts that will work? Any advice will help loads!
Every header I ever put on needed bolts either specifically for headers (like that guy you PMed) or some grade 8 home depot specials (with washers and lock washers) - only get as long as you need to get a good seal, or you end up where you are now.
There are clearance issues with all bolts. Especially when trying to put a socket on the bolts themselves. This problem could be related to my manifold gaskets i use, which i have customized by adding the proper holes to fit. The holes are off center so this could be another issue i guess.
Thanks,
Chris
Thanks,
Chris
sounds like the gaskets are turned around the wrong way if you are having alignment issues and a socket wont fit to begin with... go pick up a 10mm ratchet end wrench from VatoZone and you can thank me later for that one.... and while you are in there it may be a good idea to change the spark plugs and wires if you have the money bro...
