Help, what goes here?
Alright, took a look under the engine bay, I have a couple things missing I beileve, does anyone know what goes here? There are 2 pics, I dont have Air/Egr and I cant find the PCV so im sure it goes to one of these or something. Its a 98 LS1 and if anyone has diagrams that would help too. I also see the passenger side valve cover has a cap where a hose can be placed on it, guessing for PCV. Thanks
heres a pic of what goes there mike dont know what its called but i have an extra one of the 1st pic!the 2nd one is the pcv .... it should be a line by the back on the valve cover.... or something like that.... one plugs up to there and there should be an extra line to run all the way to the **** you are missing!! let me know if it helps.... kinda in a rush so i dont know if youll understand what im saying!!!!
nah, not worried about emissions. but does that affect anything else? besides emissions? it will throw a code though correct? I dont have egr or air installed nor do i have cats or rear o2s. Maybe i can have the evap deleted from the PCM. As long as it will drive fine without it, ill just plug it as you said. Thanks
anyone know how PCV hoses hook up on a 98? ive seen 99+ but no 98 diagrams. The perimeter valve covers dont have the same connections. On the passenger side there is a oil fil hole with a cap in there that has a place where a hose can go on top of it, i could put the pcv there for the driverside correct? Dont know how ima hold the pcv though, id have to have the correct fitting.
i might still have all the correct hose's with fittings at the house. i will not be back in Dallas untill Friday night. if i still have them you could just come by and get them. let me know if you still need and i will look in my spare parts box to see if i kept them or not. if not i can show you how to set it up to route back to the manifold. or i could show you how to bypass. pretty simple.
I can take some pictures and post them up tomorrow if you need.
ryan if you have pics, please post. thanks
I took some pictures of the old PCV lines (mine are broken and leak), where all of the connections for the PCV are made, and what I did to reconnect everything.
http://www.flickr.com/photos/10466915@N02/
Sorry for the white balance in some of the pics; my hands aren't really that white.
Hope this helps.
Hope this helps.
