Anyone wanna make some $$$? I need my clutch hydraulics bled.
I need someone to come to my apt in irving tommorow and bleed my clutch hydraulic system. If anyone can do this let me know and how much youd charge. Id prefer someone who had a mityvac or some kind of pump or something that could bleed it for me. Im not sure what the problem is but i cant get it to bleed. Also if we had to take out the master, i dont have the white ring around the connector to the slave and dont know how to get it off without it, unless someone knows.
**** for hours atleast and no pressure, i found there was dark fluid in the reservoir, which I know was really dirty and would cause no pressure because of the dirt in it. So i flushed the whole system out and it still wont bleed.
How do you have dirty fluid, its not a new master cylinder? I would figure out how to remove from the slave and bench bleed it out of the car. Maybe a quick disconnect tool would work.
im in irving everyday. off of esters.
a mity vac will **** ur **** up i will come over and bleed ur t56 if thats wat u have. 30 bucks and ill do it right.
is ur master properly bench bleed?
Need someone to help me bench bleed my clutch master cylinder.
Pulled the clutch master cylinder and need to get it bench bled. Anyone wanna help? I can bring it over and Ill pay for the help. Thanks
1 Post
i see you did an engine swap on this car... is the tranny an LS1 style or LT1 style? i know the slaves are different, but i assume the basic design of the master is the same.
anyways, i'm in SW dallas. if you don't mind making the drive, i can help you with the bench bleeding.
