Injector cleaning
Old 03-08-2008, 05:06 PM
my number 1 hater's Avatar
Default Injector cleaning
I am looking for a place to send my injectors to be cleaned.....I would like some where in the houston area.. thanks..
Old 03-08-2008, 09:35 PM
10 Second Fun Car
jlrz28's Avatar
Why not just get an injector cleaning kit? Its simple to do plus you can use it again. Works great or you can take it to a dealership and have them do it.
Old 03-08-2008, 10:36 PM
Mike96z's Avatar
x2......
Old 03-08-2008, 11:01 PM
Brian2006's Avatar
The damn dealership charges more than the freakin injectors are worth.
Do it yourself with the kit
Old 03-08-2008, 11:22 PM
wrb07sti's Avatar
Go to your local Autozone or whatever parts store and buy a botle of Lucas fuel injector cleaner/ fuel system cleaner / treatment all in one for a couple of bucks and save the trouble of removing the injectors and sending them out for cleaning. LUCAS dumdumdum!
Old 03-09-2008, 12:36 AM
Brian2006's Avatar
LUCAS is seriously overrated.
Old 03-09-2008, 08:41 AM
Cheetoh's Avatar
Berrymans works very well also...
Old 03-09-2008, 03:41 PM
The injectors are from my 98 camaro... I just put a 99ss motor in my 98... So i have the injectors out of the fuel rail and car... I plan to put them on the 99 motor because they are larger and i need them for the spray...
Old 03-09-2008, 07:03 PM
BIG ED'S 35TH SS's Avatar
use sea foam
Old 03-09-2008, 07:08 PM
Originally Posted by BIG ED'S 35TH SS
use sea foam
LOL.........
Old 03-09-2008, 07:12 PM
Cam72aro's Avatar
This stuff doesnt do anything. You need to use a injector cleaning kit that pressurizes the solution and runs the enigne off of it. Find a local shop or maybe even Fireston could do this for a cheap price. The crap in the bottle does nothing.
Old 03-09-2008, 07:32 PM
I can do this at home i have the snap on kit to pressure the system in the car but i need to get them cleaned ,flow tested and to check the spray pattern...
Old 03-09-2008, 07:35 PM
Cam72aro's Avatar
I didnt know that you wanted them flowed and check the spray pattern. All you said in your first post was cleaned. I see now. Josh
Old 03-10-2008, 07:43 AM
Whats funny about sea foam i used and it works fine!!
LOL.........
Old 03-10-2008, 11:16 AM
"All Motor 9 Second club member"
TXCAMSS's Avatar
Call Exotic Performance here -> They can clean and flow test injectors. You'll have to send ship them, but it'll cover your needs and be done right.
The other suggestions were just routine maintenance options. The kit that force feeds the injector cleaning solution into the fuel rail is the best bet for routine maintenance IMO.
G/L
Old 03-10-2008, 11:27 AM
8 Sec Tuner
Mike TexaSS's Avatar
Call NAPA. There is one store in Houston that can clean and flow your injectors. I have used them. Its off 610 by the ship channel.
