Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Is it possible to add a Alum. Spool Gun, ....
Old 02-19-2009, 11:17 AM
Stampede4ever's Avatar
Default Is it possible to add a Alum. Spool Gun, ....
to a Mig Welder that did not come with one?
Thanks.
Old 02-19-2009, 01:46 PM
MikeGyver's Avatar
What MIG welder do you have? Plenty of Millers are spool gun ready.
Old 02-19-2009, 02:45 PM
Formerly darynC-10/23/10
Daryn's Avatar
i have a lincoln 140 hd and i will be buying the magnum sg100 spool gun
Old 02-22-2009, 08:45 PM
Gordon0652's Avatar
I do not think that lincoln can support a spool gun. I could be wrong.
Old 02-22-2009, 09:33 PM
99345hp's Avatar
you better have leather sleeves if you plan on running a lot of alumimum mig. The splatter ***** coming off of it will burn the snot out of you. I personally dont like mig welding aluminum, well I would prefer to not mig weld anything, but thats besides the point.
Old 02-23-2009, 11:06 AM
I called the local dealer, cost to much for the setup. I'll buy a tig.
Thanks.
Old 02-23-2009, 04:29 PM
Gordon0652's Avatar
Originally Posted by Stampede4ever
I'll buy a tig.
Better Idea!
There is a big learning curve with a Tig...
Old 02-23-2009, 07:21 PM
99345hp's Avatar
If you have good hand eye coordination tig welding aluminum isn't that hard to do. Yes it takes practice, but I dont think its as hard as everyone puts it out to be. Post up when you get started and Ill help you out with your aluminum tig if you need it.
Old 02-23-2009, 09:48 PM
Gordon0652's Avatar
Agreed.
When i said learning curve i ment whats involved with it.
Old 02-24-2009, 06:18 AM
99345hp's Avatar
Originally Posted by Gordon0652
Agreed.
At least I'm not the only one that thinks that its not that difficult. There are many things to welding aluminum that will make it alot easier.
1. Clean, Clean, when you think its clean, clean it again.
2. You dont have to keep a super close arc length, if you do you are going to touch and contaminate your tungsten.
3. Use a decent size cup with a gas lens. You want the best gas coverage that you can to keep the weld clean.
4. Dont worry about putting a ball on the end of the tungsten before you start welding. Sharpen it to a point and it will form the ball on its own from the AC current.
5. Get yourself in a rythem. It is best when you first start to count, or weld to the beat of a song. Your welds will be more consistant this way.
Thats all I can think of right now. Good luck.
