Powder coating engine block and heads?
Is there any rule that says you cannot powder coat and engine block or the intake heads? Getting to have machine work done to some and when they are finished I really wanted to get them powder coat prior to rebuilding them. Any ideas on if it can be done?
might be "safer" for lack of a better term to powdercoat it before machine work is done.. get the block cleaned and inspected... coat then final machining.
this is just my guess could be way off just seems like a better idea to me if you was going to do it
I'm not sure but I've thought about this also. If it were possible, it would have to be done before machine work without a doubt. and you would need a deck, bore/hone, hone lifter bores etc, basically a full machine.
I own a powder coating business and i actually powder coated my own block just to see. Results were good. I had the machine shop cook, clean and then tumble roll it. I then cleaned the block with an iron phosphate bath and powder coated it chrome. Then had them do all the maching after words. After 18 dyno pulls very minimal coating loss. None that can be seen with engine assembled.
I would imagine that it would be difficult to get something with the mass of an engine block warm enough in a powdercoat oven evenly unless you have a lot of time or a fairly serious oven...
I powder coat engine blocks all the time,I have a set of heads/oil pan I use just for powder coating and it saves alot of time with covering up the engine.Never had any problems actually over time it starts to look better from the heating/cooling of the engine
so sorry to bring this back... but how long do you think the coating would last? if it doesnt last long I dont think I'd do it. I saw that when you coat your headers with that special coating (1200F) you bake it on to set it... do you do that with engine paint too to make it more resistant?
I'm not sure I would powdercoat an aluminum engine block and heads, as it would inhibit cooling to a degree.
