Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Post your best welds!
Old 08-02-2013, 05:49 AM
  #41
Camaro9969's Avatar
Some exhaust done by GMP
Old 08-12-2013, 07:00 AM
  #42
Jimbo1367's Avatar
Unobtainium,
Damn dude. Awsome welds.
Old 08-13-2013, 09:01 AM
  #43
78buturbo's Avatar
Originally Posted by Camaro9969
Thanks man! Here's what we are working on now
ill take one of those twins, sweet work
Old 08-31-2013, 01:00 PM
  #44
Closed ex-Sponsor Account
SteveDoten@ARH's Avatar
Is that a rotary TIG someone is using in here?
Seriously guys, nice work.
Old 08-31-2013, 04:28 PM
  #45
Wnts2Go10O's Avatar
:sigh: i want to learn to tig
Old 08-31-2013, 04:40 PM
  #46
jss812's Avatar
Very nice looking work. Probably the best example is the Ti weld. Looks like it might have been a little better if a trailing cup were used (I may be wrong but looks like a little trash in there, usually get that when the Ti cools without purge, so you use a trailing cup).
And I see some can walk the cup. Very nice freehand stuff too, assuming nobody cheated and dry washed!
One note. Per AWS, 6G is a position using pipe. It is a butt weld on a fixed 45. Most around here cut coupons ~1 foot long, prep the joint, tack one to a fixture on a 45, tack the other coupon to the fixed one, then weld it out. It is used to qualify welders and is not limited to stick. It can be other processes like TIG.
Welders are the most tested craft out there in the PetroChem industry. They test to prove they can weld then have a minimum of 5% of their work tested after they have passed the test. (assuming they work on fixed equipment - tanks, pressure vessels, pipe).
In another life, I worked as a millwright, then as a welder. Then I decided to try working on the other side. I would be the guy that pisses welders off, especially when they didn't do something right.
Old 09-20-2013, 08:51 PM
  #47
man-o-war's Avatar
I want to learn to TIG sooooo bad!!!!
Old 09-23-2013, 02:04 AM
  #48
Unobtainium's Avatar
Unobtainium,
Thanks Jimbo.
More pics tomorrow maybe. Been doing a ton of roll cage stuff, that and 2G/6G welding on 4130/NDA tubing.
Love the variety.
Old 09-25-2013, 09:19 PM
  #49
honda_head's Avatar
Nice work unobtanium. I think i'm going to start my own fab thread, cause I would clutter the crap out of this thread.
Keep up the nice work guys!
Old 09-26-2013, 02:09 PM
  #50
LLave's Avatar
Originally Posted by YJ Goat
[/URL]
Anyone else curious why there is an xbox connect in an armored box?
Old 09-27-2013, 09:56 PM
  #51
dirtbag's Avatar
Some great craftsmanship in here. One thing I have noticed is probably too much heat, too fast TS, or not enough wire on some of these welds. The concavity/throat under fill and undercut will lead to weld cracking on some applications. No reason to run that much heat input on such thin material. If you wanted penetration, TIG wouldn't be the first choice anyways. I'm being nit picky all welds look impressive.
Old 10-03-2013, 08:23 PM
  #52
Few pics of some 321 BMW v8 stuff done recently.
Old 10-04-2013, 11:10 AM
  #53
honda_head's Avatar
mmmm 321 is some big $$$ stuff.
Old 10-04-2013, 12:58 PM
  #54
It's a good value for stuff that gets hot.
Middle pic is 304. Went to 304 for the mid-pipe back.
Inconel is best, but it's big bucks.
Old 10-04-2013, 07:16 PM
  #55
honda_head's Avatar
is that 16 gauge stuff?
Old 10-04-2013, 09:59 PM
  #56
321 is 18, 304 is 16.
Weld to BB muffler for a blown taco
Weld to Inconel flex bellow for TT Stealth
Old 10-10-2013, 10:31 AM
  #57
Camaro9969's Avatar
Little more weldporn
Old 10-10-2013, 06:19 PM
  #58
tonypaul's Avatar
While some people go to a art museum to see works of art, the pics in this thread are true works of art!
Old 10-11-2013, 06:28 AM
  #59
Camaro9969's Avatar
Finished Product
Old 10-13-2013, 01:19 AM
  #60
The Ti weld on the used exhaust has some colour at the edges of the HAZ, but acceptable for sure.
Welding is the most tested trade, no doubt. If you can't handle pressure, it's not a good choice.
I'll post a few more pics shortly.
Quick Reply: Post your best welds!
