Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Stupid Noob Welding Question
Old 07-13-2005, 12:35 PM
87f383's Avatar
Default Stupid Welding Question...
I am pondering purchasing Lincoln Weld Pak 3200 HD wire Feed Welder Model: K2190-1 from a friend.
Its says it can handle 5/16"... does that mean I can't weld a regular exhaust pipe to a 1/2" think T3 Turbine inlet flange.
Or does that mean I can only join up to two 5/16" plate peices into one.
Confused a lil here... just want to make sure it can do what I need... which is remote turbo exhaust work.
Thanks in advance...
Old 07-13-2005, 02:24 PM
CTSmechanic's Avatar
Because the exhaust is so much thinner than a turbo flange I'd think you'll be ok...Usually the 5/16 means thickness to ensure proper penetration
Old 07-14-2005, 08:32 AM
Mr Incredible's Avatar
You can weld up to 5/16" plate. The heat is adjustable, just turn it down to where it needs to be. Where that point is will vary with machine/wire/gas and material thicknesses.
Old 07-14-2005, 10:39 AM
Diamond Jim's Avatar
Yep you can. But check out the turbine flange carefully. It may be cast. If it is get a professional to do the welding, as it welding cast involves pre-heating and controlled cooling.
Old 07-14-2005, 03:41 PM
87f383's Avatar
Thanks for the replys... Im gonna go ahead and give it a hot. Flange is mild steel...so I should be peachy.
Old 07-14-2005, 07:59 PM
Camaro Zach's Avatar
just as your welding try to keep most of the heat on the thicker metal and then drag it onto the thinner piping. That will help ensure penetration into the flange and reduce the chance of blowing through the thin tubing. Good luck
Old 08-05-2005, 04:07 PM
RFERG43's Avatar
When welding thin to thick metel I use low current to build up the thickness at the weld area on the thin metal before making the joint. Chances of burning through are nil.
Old 08-06-2005, 09:31 PM
gollum's Avatar
Lincoln is veryeasy to use but it takes practice. Flip the metal door up and it has a verygood metal thickness/ welder setting chart.
