Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Half decent double flaring tool?
Old 08-04-2005, 06:37 PM
GM Muscle's Avatar
Default Half decent double flaring tool?
So I have to flare some brake lines and I picked up a Summit double flaring tool. It looked half decent but, it's the sorriest ******* piece of **** that I've ever seen. It's going back in pieces. With that said, what flaring tools have you guys had good luck with?
Old 08-18-2005, 04:16 PM
robertbartsch's Avatar
I have an old quality set I've had for 25 years ...not sure who made it but it is OK. I bought a cheapie set from HF that is not good, however...
These guys have several different flaring tools from differnt manufacturiers:
http://www.thetoolwarehouse.net/
...buy a exensive one and hope for the best.
Old 08-23-2005, 02:42 PM
Muffracing's Avatar
I have a matco double flairing set that works great. I'm not real sure on the price. $70 or maybe $90?
Old 08-23-2005, 03:26 PM
MrDude_1's Avatar
i just rent them from autozone when i need them... works good.
Old 08-23-2005, 08:08 PM
GM Muscle's Avatar
I ended up going to home depot and grabbing a a Rigid flaring tool since the clamping bar is alittle nicer. Along with the Summit dies it works pretty well, no leaks so far.
Old 08-26-2005, 08:48 AM
derekf's Avatar
The Ridgid flare tool I saw at my local HD didn't look like it did double-flares.. if yours does, happen to know which part number yours is?
Old 08-26-2005, 06:44 PM
GM Muscle's Avatar
No the Ridgid is not a double flare tool. I had to use the dies from the Summit kit. Basicly just bought the Rigid for the clamping bar.
Old 09-18-2005, 09:43 PM
wanklin's Avatar
yeah, it's all in the dies. If that doesn't work out for you I'll go out to the garage and remind myself which dies I have. I basically just bought a decent clamp and a really nice set of dies.
Make sure you smooth all the burs before you flare. ;o)
-Rob
Old 09-21-2005, 10:16 AM
SJM Manufacturing Inc's Avatar
We sell double flare tools with our line lock and ABS delete kits...we also sell them seperatly for anyone for 25.00 shipped.
We tig weld a new bolt part-way down the flaring bar to decrease deformaton in the flaring bar. The flaring bar itself it typically what deforms while flaring making the tube slip as you flare it. The less expensive units (<50.00) are pretty much all the same.
The only way you can get a quality kit is if you spend quite a bit of money. Typically you do get what you pay for. These are things like what we use...but we use them everyday...the cost and function warrants itself.
Old 09-21-2005, 02:56 PM
CTSmechanic's Avatar
Sikes Pickavant...avalible from Pro Sytem brakes(Brembo dist.) without a doubt the best double flaring tool you can by I have used one for a few years and never had a problem...
Old 09-21-2005, 08:48 PM
BJM
BJM's Avatar
I just went through this with a cheap flaring tool I have. They all look the same to me so I am reluctant to spend a lot and still have a piece of crap. I managed to double flare some brake lines on one of my cars on Saturday when a line corroded apart but there is no way I could ever get the thing to flare anything bigger than 3/16" line. I tried 1/4" for fun and all it would do is mangle it. Is there a URL for this Sikes Pickavant brand?
Old 09-21-2005, 09:15 PM
They all are pretty much the same...at least the inexpensive ones.
Minor differences...i've looked into a variety of them for customers and came up with what I described above as they all had their shortcomings... the modification we made makes them work much better. The problem is the clamping force needed for the tubing with the standard setups allows the tube to slip. By modifing them the force applied is moved closer to the tubing...this lowers the deflection of the flaring bar increasing the pressure on the tubing.. We would be happy to sell higher end models though truthfully, the ones we have and how they are modified works rather well.
They are nothing you'd want to use as an everday tool, but most certainly does the job and lasts quite a long time. Most folks do not want to spend 75+ for a tool they will use once in a blue moon.
Old 09-24-2005, 02:38 PM
shep28's Avatar
I have bought two double flaring tools and they both end up slipping when you tighten the flaring nut. Do you know of any that will not do this?
Old 09-24-2005, 02:41 PM
shep28's Avatar
How can I get one of these modified flaring tools that you speak of?
Shep
edukatek12@aol.com
Old 09-24-2005, 02:56 PM
[QUOTE=shep28]How can I get one of these modified flaring tools that you speak of?QUOTE]
Shep,
We sell them with our ABS delete kits. We do sell them separatly if you need one. They are available for purchase though our online ordering on our website under the braking section.
A tip for you is if you already attempted to flare the tube, if it slips, more then likely the best thing to do is just cut off 1/2 inch were it was compressed. Once the tube has compressed, you'll more then likely never have sucess on that tube since it's already reduced in diameter.
Steve
Quick Reply: Half decent double flaring tool?
