2-post Asymmetrical lift or 4 post-rack??
Well we are hopefully rebuilding my garage at my house and I plan on putting a lift in. But I am kind of indecisive on what kind of lift I want to put in. So I did some pro's and cons of each but I would like to hear what you guys think.
2 POST
Pros
- easier to get wheels off and work on suspension stuff.
- a little cheaper in the long run
Cons
- My car is pretty low and I dont want to have to jack the car up to get it on the lift arms.
-doesnt seem as sturdy/safe as a rack.
4 POST
Pros
-car drives right onto the ramp, a lot less work to get up.
-Sturdier to store cars under (peace of mind)
Cons
-Harder to get the wheels in the air and off.
-Would need to get expensive jack to lift car off ramp(heard they are fumbly bumbly as well)
Im no expert on this, because I have never really had experience with lifts, but this is what Ive seen so far. Any suggestions are appreciated...Thanks.
Chris
2 POST
Pros
Cons
4 POST
Pros
Cons
Chris
my dad has a 2 post sitting in our old garage waiting to be installed in the new garage. I can let you know how much ground clearance a car would need to have in order to avoid having to be jacked up first once it is installed (couple more weeks.) However I dont think that will be an issue for you.
here's our new garage. Its almost done now the only thing left is landscaping and putting in the lift
2 post just my opinion i have used a 4 post and use a 2 post at the dealership i work at . i definately would go with the 2 post lift even know u might have to jack the car up to get the arms under it
Also, you need to consider your base foundation if your going to think about a 2 post. you need at least 5 inches of cement below where you need to drill the holes for the lag bolts that hold your lift up. if you are not sure or have anything less than 5 inches, then it is a safety hazard and quite frankly, you'd be stupid to buy it and find out later. Go find an inconspicuous spot in your floor and drill it and measure it (If you dont know the actual depth, that is. ) We've set up 2 2-post lifts and 2 4-post lifts and I would vote for teh 2 post over and over again for simplicity of operation, timeliness of construcion, and overall flexibility for use and stability.
On a side note, I have a Eibach pro-kit and I have to jack up my car until I can slide the lift pads under and set them up so they don't hit my factory ground effects. On a non ground effected car, I've put a LT1 with Sportlines on the 2 post with no jacking.
IMO, if you are looking to get the most out of a lift, and your money of course, go with the 2 post.
BUT!!!
A 2 post lift is NOT intended to hold vehicles for long periods of time like a storage lift (4-post), and if left on a lift for long periods, i.e. suspension swaps or something where you cannot lower the vehicle again until you get more parts, YOU WILL CAUSE THE CAR TO SAG! AND NOT JUST UNI-BODIES!We've seen it time and time again where long term project cars have door fitment issues and body panel fitment issues because they sat on a 2 post lift for extended periods of time. Case in point, a 55 Bel Air at a local bodyshop has been in the rebuild process for two years, and all the body panels -USED- to fit flush. Now the doors are showing signs of sagging out, and the front clip NO LONGER FITS LIKE INTENDED!
In reality, you have to ask yourself what you really need a lift for. If its for storing your toys, then by all means, do the 4 post. But if you want somewhere to work, you are better off with a 2 post.
BUT!!!
We will be building the garage from the ground up and we will have a really strong base, so thats not to worry. I want a lift for working on the car mainly. But honestly I do not want to mess around with jacking it up to get the pads underneath. But I would also want to occasionally want to store a vehical underneath it. However I am leaning towards the 2 post. Everyone of my friends who are in that field have recommended 2 post lifts. Maybe I should get both...lol.
Have you looked at this type of lift. You have to navigate to the scissor lifts, the Space Max 700. Here it is in my garage. I have since moved the garage door opener out of the way and the car goes up high enough to let me roll around under the car on a desk chair. The lift itself can lift up over 6 feet in the air like other lifts, my ceiling is too low.
Hmm I think i just solved my own problem...Wha do you guys think about this. It seems to be exactly what I need.
http://www.asedeals.com/two_post_pad_lifts.html
Originally Posted by Phoenix57
BJM, how hard is it to work on the drivetrain with that style lift. we are building a garage soon and are trying to decide on what type of lift to get.
Some good features, floor thickness and strength is not a concern since the load is spread over such a huge area. I can easily move the lift single handed using an engine lift since the two halves move separately and the ramps at the front and back come off. Best feature of all, you can get rid of the ramps completely and put the lift pieces into the floor so they are flush when its down. There would be nothing at all in your way when you were not using the lift. I plan to do that myself at some point myself. They are only 9.5" thick when lowered though.
this sounds perfect for what we want. thanks for the info. so you can easily move the lift out of the way? that sounds nice, that way we can use the area for other things when we don't need to work on the cars
Question for you guys. Would it be safer to store vehicles on this type of lift compared to a regular 2 post lift with the arms? Also do you think there would be clearance issues when driving over the ramps?
Like said above you don't want to store a car for a long period of time on anything that will have the suspension unloaded. It needs to be stored sitting on all four tires. I have notice from working with many different style lifts that you probably will not be able to get your car on a cheap 2 post. My TA sits kinda low and it will not get on a lift that uses screw type pads such as the harbor freight lift and other cheap lifts. The only lifts I have been able to get my car on are Rotary lifts. The pads are very low. If you have to you can always lay some 2X12's in the floor and drive up on them before you set the rack. If your going to work on the car you need a 2 post, if your main concern is storage get a 4 post.
