It's starting to get cold. How do you keep your garage warm?
I'm not talking about a permanent solution as the garage is old and I work on my car in my dad's garage. I need something that I can throw in there and heat it up so that my hands don't get frostbite after touching bare metal. What kind of heaters are you all using?
Links, prices, and pics are always helpful.
Brian
Brian
I use this http://www.grainger.com/Grainger/pro...541217&ccitem= in a 20x30 / 10' ceiling shop. It is well insulated with 6" bats in the walls and 10" bats in the ceiling. It will cycle on and off with 30* outside temps keeping the shop very comfortable to work in. I like the electric heat because you don't have to worry about venting or fumes. You will need a 30A 220 circuit for it. The 110v heaters are pretty worthless as you are limited to only 1500W.
Jet type heaters work wonders. You can use Kerosene, Diesel, or other forms of similar fuel. Kerosene burns the cleanest, and doesnt knock you out from the smell.
http://www.northerntool.com/webapp/w...24&R=200166924
Originally Posted by 72ChevelleConv.LS1
50 foot 250,000 BTU IR tube. Cheep to run or least the wife didn't cry when the bills came in last year. cost more to buy but will work out in the end.
garage is 30'x24' well insulated metal building. I use a Coleman 45,000 btu radiant heater that runs off propane tank. put fan behind it and after 20-30 minutes on sub 40 degrees days i can walk around in t-shirt. i cycle it on and off every 20-30 minutes to save on propane and because it get to hot. bought it at Home Depot for 79.99? might have been 89.99 cant remember...
Heater
I bought the Modine, Hot Dawg unit last year for my 25x25 garage and that baby works great. Only pain was that I had to run a natural gas line, but they do sell it for Propane as well. I highly recommend the Modine, Hot Dawg
