Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Reducing spatter
Old 12-01-2006, 12:28 PM
Moderator
LIL SS's Avatar
Default Reducing spatter
I have figured out how to get decent beads, no how do I reduce spatter?
I’m not exactly sure what the wire is as it was on the welder already. I know it looks like an ER70 of some sort. I see -3 and -6 listed at a couple places stating -6 has less spatter. Might try that.
Gas is a 85/15 mix
Old 12-01-2006, 01:29 PM
xfactor_pitbulls's Avatar
Anti splatter spray broham. Does a world of good when you are running the mig. Pick it up at any welding supply. Also, get a good stainelss wire wheel on a 4 1/2" grinder. That will blow off most of what you have on there. The rest comes off pretty well with a 12" straight mill file.
Brandon
Old 12-02-2006, 04:07 AM
terr1bleone's Avatar
i always got rid of my spatter running straigh argon for gas. little pricey though for mig i think.
Old 12-02-2006, 01:37 PM
TA4EVR's Avatar
that type of gas will splatter a little more then say a 75/25 mixture. also like the next guy said, pulse welding is a little different, try a little bit more heat or different gas
Old 12-02-2006, 03:42 PM
CTSmechanic's Avatar
10-4 on the anti spatter also I think the start and stop method produces more spatter than constany welding... thats the way it seems to work for me.. I TIG weld everything I do...
Old 12-02-2006, 08:08 PM
Moderator
LIL SS's Avatar
Doesn't make a difference pulsing or continuos. I get the same amount of spatter. I have tried a 75/25 mix but it was before I had a good handle on temp, speed and technique. I think I'm try some antispatter spray and maybe the 75/25 mix again.
Old 12-04-2006, 01:16 PM
JeepinBash's Avatar
you shoulda hit those tabs with a 120 flap wheel instead of leaving the grinding rock rash behind. it makes a huge difference in appearance. off subject i know but it was the first thing i noticed in the pics.
Old 12-04-2006, 01:45 PM
MrDude_1's Avatar
i know this sounds silly, but i was welding on my car this weekend and was having a similar problem... i bumped the gas up to 35psi and it seemed to help...
really though, i think its the wire... i ran out and i tossed in the spool that came with the welder (this spool is ~3 years old)...
does the gas pressure really have an effect on splatter, or was that just a placebo effect?
Old 12-04-2006, 03:59 PM
TA4EVR's Avatar
if you dont have enough it will matter. 15-20 should be good if theres no fans on you or anything blowin it away. 20 up to 35 shouldnt make much difference unless you had some blowing away
Old 12-12-2006, 01:31 AM
2001CamaroGuy's Avatar
wow...I don't think I have EVER had spatter.....when I say EVER I mean EVER! I'm running a 75/25, Ar/CO2 mix on a Miller 185.....the ONLY time I EVER have to "dress up" the welds is if I honestly DO NOT WANT A WELD......
the welds look good and there are even little "hot spots" so I would agree with everyone and say "check the gas".....
if you REALLY want to play, I have been told Helium (I think that was it.....it was quite a while ago) does wonders (never tried it)
Helium was used back in the day as the first shielding gas for a little welding process know as heli-arc (tig). It was replaced by argon and argon mixes. If you didnt use anti-platter or something of the like you had some splatter. Maybe it wasnt bad, but there was some.
