engine building tools-online?
Does anyone know of any specific places that sell decent engine building tools online? I'm looking for places that have more of a selection besides summit or Jegs. but won't break the bank like snap on or mac. Throw up some links if anyone knows of some places.
Your local auto parts store should have a tool section. There you'll find most of what you need to build a motor. Otherwise a good torque wrench and set of 6-sided sockets are all you need.
I have found the following vendor to be a good source for hard-core tools:
http://www.precisionmeasure.com/
Occasionally, I troll through Ebay Automotive Parts and Accessories and I've picked up some good values there as well.
Just because you can BOLT it all together, doesn't mean it's built correctly
There's a lot of measuring, bearing clearance checking, block deburring, sonic checking, magnafluxing, rod bolt stretch measurements, etc. etc. etc. etc. that goes into a GOOD "blueprinted" motor build. It's all up to whether you want a motor simply bolted together into a single chunk of bits, or you want a motor assembled knowing it's built properly.
he's right, yeah you start throwing it together and getting bearing clearances wrong and having oil pressure issues and your gonna wish you would have just paid a machine shop to assemble it. i promise it will be money well spent
www.thetoolwarehouse.net
thats where I used to buy stuff if it wasn't off the tool truck
however, when it comes to lower end assembly, I plead with customers, just let a machine shop do it. Even if its not ours.
Everything on the block is based around the main journal bore, nobody has a line hone in their garage, so their no proper assembly done without this.
Location: sneaking in your back door as you leave!/cartersville ga
i believe it is http://kalecoauto.com/index.php?main...a210a4ab0dc5fc its were i get all my stuff
