FS: 02 SS blk m6 cam only
Year: 1950
Make: Chevrolet
Model: Camaro
Price: $15500
Mileage: 45000
Private or Dealer Listing: Private Listing
Location (State): TX
Color: Beige
Transmission: Automatic
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
Since buying the car, mods include:
Motor: 1500 miles on cam, etc
MS3 113 lsa
PAC doubles
ls6 oil pump
7.400 pushrods
42 lb green tops
UPD lid
Chris 1311 ram air (non ac version)
Pacesetter headers/Y
Bullet
Transmission: 1500 miles on clutch, etc
Monster stage 3 clutch
Light weight flywheel
McCleoud Bellhousing
Tick MC w/speed bleeder
Stock hurst shifter/with umi short stick
Suspension:
Dana 60 4.10 tru trac
Midwest chassis: LCA, PB, tunnel mount torque arm, (all double adjustable)
Umi drag/sway bar
moved battery to rear
Strange double adjustable shocks in the rear
Brakes:
SJM abs delete and line lock
all buttons mounted in ashtray
Shift light is mounted in the A pillar defroster hole. I also have an extra set of stock 16x8 with a set of 26 inch tall et streets that will go with the car. The tires/car has 10 passes on them. Best so far is 12.22 at 116 with a 1.85 60ft. They car weighs 3400 without me in it.
I am located in San Antonio, Texas. I can email more pictures of the car if you send me your email address. $15500
