Notices
Vehicle Classifieds This an archive of the older vehicle classifieds, please create a new listing in our Marketplace.
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
Street/Strip 93Z 385 LT1, LS1 Front End, Moser etc
Old 03-13-2013, 04:29 PM
GearJamma's Avatar
Default Street/Strip 93Z 385 LT1, LS1 Front End, Moser etc
Year: 1993
Make: Chevrolet
Model: Camaro
Price: $7000
Mileage: 134900
Private or Dealer Listing: Private Listing
Location (State): OK
Color: Black
Transmission: Manual
Drivetrain: Rear Wheel Drive
We’ll finally decided to sell my Camaro to move on to other things. This is not your typical 93 LT1. It has all the best go fast goodies; built to be a reliable street/strip animal!
This car started life as Black 93 Camaro Z28 Auto hardtop, now has M6, T-Tops, and LS1 front end and interior. Has brand new 385 with only 300 miles, still breaking in. Engine runs stronger than your average LT1. Set up to put out 430+ WHP thru its moser 9” rear once broken in and fully dyno tuned.
Asking $10,000 which is about a third of what I have in it.
Comprehensive list of mods below:
Block: Assembled by DRE (Dragon Race Engineering) in Colorado
385 cid- Bored, Stroked, Decked, Honed, Clearanced, and Balanced
Mahle forged .040 pistons (-5cc flattops) ~11:1 Compr
Eagle 6 inch H-beam rods
Eagle 4340 crankshaft (3.75 Stroke)
Clevite Bearings
GM Timing Chain
GM High Pressure Oil Pump
Canton Road Race Oil Pan and Pickup
Heads:
Stock LT1 Castings Ported by Lloyd Elliot
2.02/1.60 Valves
Peak Flow #s in 270s
Valvetrain:
Custom Schneider Racing cam. 236/242 .575/.585 113 LSA
Comp Pro-Magnum roller rockers. 7/16 stud, NSA, 1.6 ratio
Chromoly Pushrods
Comp Cams Dual Valve springs
Engine Works Lifters
Fuel/Intake/Exhaust:
36# Bosch Injectors
Racetronix fuel pump kit
LE Ported Intake
Holley 58mm TB
K&N FIPK
Pacesetter Long Tube Headers
!CATS/EGR
Custom 3" Exhaust
Drivetrain:
T56 Transmission
SPEC Stage 3+ Clutch
SPEC Billet Steel Flywheel
Skip Shift Eliminator
Hurst Line Loc and Shift ****
Moser 9” rear w/truetrac and 4.11 gears
31 Spline Axles
3” chromoly driveshaft
BMR torque arm
Lakewood 1350 U joints
Suspension:
LS1 Front Brakes and Master Cylinder
No ABS, replaced with Wilwood Proportioning Valve
Jamex Lowering Springs (1.5")
Subframe Connectors (Weld-In)
Boxed Lower Control Arms
LCA Relocation Brackets
Hotchkis double Adj. Panhard Bar
Replaced Poly Bushings in the front control arms, new balljoints, new inner/outer tie rods, new link pins, new shocks/struts.
Other:
CSR EWP
Hypertech 160 Thermostat
New GM Optispark
NGK TR55 Plugs
MSD6AL Ignition
94/95 PCM/Harness (OBD1)
Mail Order tune by Ed Wright @ FASTCHIP.COM
NGK O2 sensors
New AC compressor/plumbing
Appearance:
LS1 Front End
New Paintjob (Original Onyx Black in 2006)
T-Tops new style
Full LS1 interior from a 2000 SS
SS Hood w/ SS Badging
LG Motorsports 3" Spoiler
97+ Taillamps
Clear Front Corners
Polished 17/18 Z06 wheels/ firestone wide oval tires
35% Window Tint
*New engine, clutch installed at 134,665 miles
The negatives, currently front seal leaves a drop of oil, pulleys squeak.
Old 03-14-2013, 12:19 AM
mylilpony71's Avatar
I'd just part it out you would get what you're asking easily. Beautiful car I love a properly set up ltx. If you part it I'm interested in the heads and rear end.
Old 03-15-2013, 10:36 AM
GearJamma's Avatar
Yeah, I dont have the time or space to part it out right now. No trades either.
Weekend price hack, asking $8,500 OBO!
Old 03-15-2013, 05:37 PM
95mysticta's Avatar
Can you please take a video of the car running and do a walk around and some revs to help everyone get a better idea of the car would help A LOT!
Old 03-18-2013, 10:31 PM
GearJamma's Avatar
Finally got around to making some vids. I am motivated to sell... price now $7,000 OBO!
Old 03-21-2013, 10:32 PM
GearJamma's Avatar
Bump... Make me an offer!
Old 03-21-2013, 10:59 PM
1995 330ti's Avatar
Any dyno numbers?
Old 03-21-2013, 11:11 PM
GearJamma's Avatar
Not on the 385. It made 389rwhp on the stock block with the same heads and intake but slightly smaller cam. That was thru the moser 9" as well.
Old 03-21-2013, 11:28 PM
1995 330ti's Avatar
I would love to take a look at her i wihs you were not so far. it has a canned tune correct?
Old 03-22-2013, 12:21 AM
GearJamma's Avatar
Yeah, mail order tune by fastchip for my set up.
Old 03-23-2013, 01:08 PM
GearJamma's Avatar
I sold it.
Quick Reply: Street/Strip 93Z 385 LT1, LS1 Front End, Moser etc
