Fs/ft: 01 c5 z06- Heads, Cam, Nitrous plus much more
Year: 2001
Make: Chevrolet
Model: Corvette
Price: $24000
Mileage: 77774
Private or Dealer Listing: Private Listing
Location (State): NC
Color: Silver
Transmission: Manual
Drivetrain: Rear Wheel Drive
List of mods below:
ENGINE:
Ls6 stock shortblock(pistons re-ringed for the known 01 oil problem)
TFS 215 heads(58cc)
Bronze Valve guides
Dual .650" springs
Ls3 valves
Comp trunion kit
Hardened 7.400 pushrods
ARP head bolts
MLS gaskets
VRX5 camshaft
Katech C5r timing chain
Melling oil pump
Norris Catch Can
INTAKE:
FAST 102
NW 102 TB
Vararam intake w/power duct
EXHAUST:
LG street longtubes
LG off road x pipe
SLP loudmouth
DRIVETRAIN:
Sock drivetrain
Ls7 clutch kit
POWER ADDER:
Nitrous Outlet 102 plate kit
Window Switch / TPS Controller
Nitrous Outlet Heated 10lb/15lb Nitrous Bottle Bracket
Nitrous Pressure Gauge
Nitrous Outlet Fuel Pressure Safety Switch
Nitrous Outlet Male NHRA Valve
Nitrous Outlet 180* Blow Down Tube
Nitrous Outlet 4an Purge Kit
Nitrous Outlet Corvette C5 Switch Panel
Katech Tensioner Pulley
WHEELS AND SUPENSION:
C6z wheels
NT555r DR(305/35/18)
Lowered on stock bolts
FUEL:
Ls2 Fuel Rails
60lb Injectors
Racetronix Fuel pump
Hotwire kit
Exterior:
Tinted Windows
Black out kit
Black out lower rear(Vinyl)
Split Spoiler
LED Reverse lights
Interior:
Corbeau A4s
LED interior lights
Xm headunit w/Bluetooth and Ipod hookup
C6 shift ****
Sounds like a good deal man but im looking to try out the turbo route now. Cars sound great and the silver one on weld rts look great. GL with the trade and I may consider this in time if available.
How long have the mods been on the car? How many bottles of nitrous have been ran through the motor? Do you still have the drag pack?
I have a 96 Camaro that is NHRA 8.50 certifed that I would consider trading you. It is a bolt on LS1/T56 with 58k on the clock, but the BMR suspension, narrowed 9in rear, Aeromotive 1000 fuel system, and most the parts are new. Manual Brakes, power steering, prop valve, line lock, manual locks and windows
This car has been engineered to be easy to work on, and has a ton of custom fabrication. The motor and trans can be dropped without disconnecting the brakes, fuel pump and filters in trunk for easy access, drain plugs and fill caps in everything.
Thanks for the offer promaroz but im mainly looking for something complete, turn key ready to go. Sounds like you have a great build going so far. To answer the questions for anyone wanting to know. All the mods wasn't installed at the same time but the cam/intake has 1000mi on them, heads have maybe 500mi on them. 2 complete bottles have been sprayed(1 on the dyno and the other at the track). Thanks
BLWN1- I just would rather find something already complete as stated above. Thanks.
Thanks and honestly I don't even know buddy. Too me id say its the carvaggio spoiler but cut into 2 pieces. Truly 1 of a kind because I haven't seen another one like it.
My car is getting painted right now, so it will be turn key and ready to go. I'm not concerned about the nitrous, so keep it for when you get my car. I get it back in a couple weeks. Let me know if interested
I have a 03 black whipple cobra sra and built motor. makes 591/553 16lbs on 91 and 623/601 on 110 and 21lbs. Car is nice and I have title in hand. if you're interested pm me
