Notices
Vehicle Classifieds This an archive of the older vehicle classifieds, please create a new listing in our Marketplace.
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
Built 2001 WS6 Trans Am
Old 02-13-2016, 12:29 PM
mdrnmscle2001's Avatar
Default Built 2001 WS6 Trans Am
Year: 2001
Make: Pontiac
Model: Trans Am
Price: $15000
Mileage: 5000
Private or Dealer Listing: Private Listing
Location (State): TX
Color: White
Transmission: Manual
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
2001 Trans Am WS6 Fully built car
Engine mods:
383 build using original LS1 block
Wiseco -3cc pistons
Callies Compstar H-beam Rods
Callies Compstar 4.00" crank
ARP head studs
GM head gaskets
PRC 227cc CNC ported heads 62cc chamber
11.5:1 compression
244/248 .612/.615 112LSA cam
FAST 102 intake
Nick williams 102 throttle body
42LB bosch injectors
TSP 1 7/8" headers and off road y-pipe
85mm MAF
Build has about 5000 miles since completed
Made 500 HP and 475 FTLBS on a Dynojet
Transmission build:
Spec Stage 3 clutch new when motor was built
New SPEC Billet Steel Flywheel
New Slave Cylinder
Tick Adjustable Master Cylinder
Level 2 built T56 using Tick rebuild parts with all new bearings
Other Driveline:
Midwest Chassis 9" with Long torque Arm
Back Brace
35 Spline Axles
3 Channel ABS retained
Strange S-trac
Yukon Case Upgrade
Aluminum pinion support
PST aluminum Driveshaft
Line Lock
Suspension and chassis:
Tubular lower control arms Double adjustable
Tubular Panhard bar Double Adjustable
BMR boxed weld in subframe connectors
Front upper control arms
Front strange coil over single adjustable
UMI solid motor mounts
The body of the car has 185000 miles on it.
Has typical tear in driver seat bolster
T-tops have never leaked
Never been in any accidents
I do not need to sell the car by any means i just have lost interest in it and do not drive it anymore
Clean Texas Blue Title in hand
Car is about 20MIN from Georgetown
Text is best unless it is after 6 central time.
806-316-122zero
Asking $15,000 OBO
Old 02-13-2016, 04:12 PM
Old 02-14-2016, 05:05 PM
sunday bump
Old 02-15-2016, 08:23 AM
Monday bump
Old 02-16-2016, 08:08 AM
Tuesday Bump
Old 02-18-2016, 07:33 AM
thursday bump
Old 02-22-2016, 09:15 PM
Monday bump again
Old 02-22-2016, 09:35 PM
WIKDLS2's Avatar
Should really change the add to read 185,000 miles rather than 5,000. Very misleading.
Old 07-03-2016, 05:22 PM
NewOrleansLT1's Avatar
Originally Posted by mdrnmscle2001
Monday bump again
Clean car.. I wish I had money to blow..
Quick Reply: Built 2001 WS6 Trans Am
