Vehicles Wanted Looking for a specific vehicle? Post a WANTED thread here. DO NOT post them anywhere else!
looking for an LS1 swapped V6
Old 08-15-2006, 10:21 PM
JoeKnowsBaseball's Avatar
Default looking for an LS1 swapped V6
i'm looking for a V6 camaro or firebird with an LS1 MOTOR swap. i saw the perfect car a while ago but wasn't ready to buy at the time. it was a 1994 V6 that had an LS1 V8 swap and t-top conversion. it sold for around $7K. the distance doesn't bother me for the right car so post up and let me know what you got.
also i have a 1994 3.4L v6 camaro a4, t-top, white with black accents that could trade for some off the price. (if you were looking into doing the swap again)
Old 08-15-2006, 11:13 PM
ROCNDAV's Avatar
hmm, sometimes I get so fustrated that I think of selling it!
Old 08-16-2006, 02:36 PM
does it have an LS1 V8?
Old 08-16-2006, 10:36 PM
ROCNDAV's Avatar
See sig. I'm hoping to get 15-20 hp more than the stock 3.4
Im still not done with the conversion. One day, I will be.
Old 08-28-2006, 07:53 PM
to the top
Old 10-01-2006, 12:19 AM
T T T
Old 10-03-2006, 05:21 PM
searay90's Avatar
go to ls2.com and look for a user "Tom Sawyer". He lives in Argyle and has what you are looking for. Don't know him, just saw the post over there
Old 10-04-2006, 09:18 PM
megathumpzilla's Avatar
here you go
https://ls1tech.com/forums/showthrea...03#post5608803
Old 10-13-2006, 05:33 PM
2001blkformulaws6's Avatar
Default 2001 v6 to formula conversion
if you are still interested i will post some pics
2001 black formula ws6 4speed auto with 30th anny and daytona style metalic gold stripes
17" wheels from a 96 ws6 powdercoated golden guage metalic
tail light black outs,
has factory ground effects(only way to tell it is not a real formula)
all badges have been changed has ws6 badging as well
slp long tube off road headers, slp cats, slp dual dual loudmouth exhaust,
ls6 intake, egr and air pump removed, installed alum driveshaft
suncoast creations ram air hood and kit, slp bolt on subframe connectors, slp reinforced pan hard bar, slp reinforced rear control arms, conversion was done by me 3 years ago instrument cluster shows 90k but engine actual is around 80k and trans rebuilt 1k ago, only thing under hood that does not look original is heater hoses i did not put factory hoses back on. fuel pump, fuel lines, radiator, ac, ac hoses, power steering all changed with conversion as was plugs and wires,
interior is stock with monsoon system and wires for subs and amp no longer in car, has t-tops, taupe/pewter cloth interior.
willing to part for around $13,000 obo
i also still have but may be selling original engine/trans(only 27,719 miles ran perfect when removed was still under warrenty at the time), wiring, pcm, cradle, pedal assembly, radiator, fuel pump, fuel lines, heater hoses, ac hoses, power steering resivor, black stock hood(near perfect), instrument cluster, rear panel that says firebird goes between taillights, steel drive shaft, i also have ls1 intake, ls1 manifolds, egr and air pump that was on engine, also slp take off front springs and a steering rack from a 98 z28 was told i would need different one but mine was same part number, there is also some front suspension parts that were on unusable cradle i got with engine such as sway bar and front control arms
Old 10-13-2006, 07:44 PM
yomama's Avatar
i have a 96 camaro v6 that has an ls1 swap done, its actually a hand built late model ls1with a z06 cam. Pm me for more info if interested , ihave been thinking of selling it but neverthought about it seriously till now
Ryan
Old 10-15-2006, 03:31 PM
ws6on19s's Avatar
how about a white 95 firebird with t-tops and a built ls1 motor coming with it? $8000. email me at trans195@aol.com
Quick Reply: looking for an LS1 swapped V6
