Western Members CA, AZ, NV, UT, CO, NM, HI
WTF I didn't know that it was possible?
Old 06-10-2009, 05:19 PM
DarkKnightRider's Avatar
Default WTF I didn't know that it was possible?
So I just had my motor rebuilt. It's .030 over. Has a new cam new lifters new pushrods andnew lifters. They also put in a new timing chain. I was driving Sunday night and timing chain snapped in three places! WTF. I didn't know that could happen. Now I'm looking for a new timing chain set along with a new timing cover because the old one broke in half.
Old 06-10-2009, 05:45 PM
ss.slp.ls1's Avatar
It can happen but it is rare. Where did you have the work done? Hopefully it wasn't a shady shop.
If all you needed was a new timing chain and new timing cover I would be very very surprised. Usually your valves will hit pistons and bend them...or all sorts of other carnage.
I would remove your valve covers and check it thouroughly. I would also perform a leak down test.
Old 06-10-2009, 05:49 PM
No the shop isn't shady they are covering most everything under warranty. But what I want to know is why it snapped. And if I can get a stronger timing chain for my car. The one that snapped was a stock replacement from cloyes.
Old 06-10-2009, 06:09 PM
ss.slp.ls1's Avatar
No one can tell you why it snapped over the internet...
It wouldn't hurt to get a Cloyes double roller. But you will have to delete your relctor ring and tune out the cps code. You also have to run an EWP to use the double roller. Not to forget you have to clearance the inside of your new timing cover a little. Since you need a new one, it would be best to get a '95 cover that does not have the hole for the CPS sensor.
Old 06-10-2009, 06:19 PM
Do you know if anyone makes a gear set for these cars?
Old 06-10-2009, 06:52 PM
ss.slp.ls1's Avatar
You mean a timing gear set? No one does. Getting a double roller is more than sufficient.
Old 06-10-2009, 10:01 PM
topfig1's Avatar
All things mechanical can fail. Sucks for you. Hopefully you can get it fixed and on the road soon.
Fig
Old 06-10-2009, 10:04 PM
XpEdItIoUs's Avatar
Harmonics can be to blame for this. Are you using a aftermarket balancer?
Old 06-10-2009, 10:21 PM
ConElite's Avatar
U can run a heavy duty chain. I think the LT4 one.
Damn I forgot which one my brother ran on his 383 build.
Old 06-10-2009, 10:36 PM
I looked into the lt4 chain but I would need to switch to an opti2. Along with a few other things. I just don't want this happening agian. Also I'm not using an after market harmonic balancer.
Old 06-11-2009, 02:43 AM
6LITEREATER's Avatar
Pretty sure Comp Cams does...
Old 06-11-2009, 11:30 AM
ss.slp.ls1's Avatar
Oh ****...I thought you had a '96 for some reason...
You didn't answer XpEdItIoUs' question. Are you using an aftermarket harmonic balancer? Do you put the stock flexplate back on?
Being that you have a '94 you don't have many options for a timing set. A new stock replacement timing set should work fine.
You can get a new stock timing set from GMPartsDirect.com
crank sprocket - part#: 10128346 $27.13
cam sprocket - part#: 10128349 $34.88
chain - part#: 10128485 $30.37
If you want to run a double roller, you will have to get a vented opti and a vented timing cover (but you need a new one anyway). Get a '95 cover if you go that route. You will need to get a '96-'97 crank hub because they are shorter and will work with the bigger crank sprocket of a double roller and allow your accessories to align properly. Let me know if you have any questions about it.
Old 06-11-2009, 04:47 PM
stock harmonic balancer and flexplate I believe. I just don't want this happening agian. My mechanic thinks that the chain snapped because of the higher pressure springs I have in the car. But I'm not sure.
Old 06-11-2009, 05:16 PM
ss.slp.ls1's Avatar
Negative...
Are you sure this is a reputable shop?
Old 06-11-2009, 06:21 PM
Ya. They just aren't a performance shop. They have always treated me right and been on the level with me.
Quick Reply: WTF I didn't know that it was possible?
