Western Members CA, AZ, NV, UT, CO, NM, HI
help!
Old 08-30-2009, 11:09 AM
impstrz28's Avatar
Default help!
My car had been making a little tiking sound so i was going to look at it after work. On the way home it got louder and then it just stopped, but the car felt different. i opened up the valve cover and the #1 intake rocker bolt was broken. i had to drill it out re tap it and replace the bolt. when i started the car up again(valve cover still off) you could hear a really loud noise on the #1 cylinder. so my valve is fucked right? i dont have the money to fix it right now and i still need the car to get to work so my question is: will it be ok if i take out the rod and rocker arm for the #1 intake valve, put everything back together and disconect the fuel injector and ignition coil and just drive it on 7 cylinders? any input will help thanks!
Old 08-30-2009, 11:14 AM
rice8er's Avatar
I've got a set of stock heads of my 01z28 ill sell u for $250 shipped.
did the pushrod break???
Old 08-30-2009, 11:28 AM
00SSLS1's Avatar
I've got stock 853 heads fully assembled with dual springs, plus my stock rockers if you need them
Old 08-30-2009, 11:57 AM
BigDaddyBry's Avatar
Set of 241s for sale here, a little over 50k on them, $125.
Old 08-30-2009, 02:29 PM
impstrz28's Avatar
thanks guys, but i only have 40 bucks for gas. you guys think ill be ok on 7 cyl. till i can gather enough to fix it(about 3 weeks)?
Old 08-30-2009, 02:49 PM
Black02LS1's Avatar
Yea i think youll be ok. As long as there is nothing that fell into the cylinder. Plus it doesnt sound like you have much of an option. I would pull the spark plug to that cylinder as well, that way you dont get that anoying Jake-Brake effect.
Old 08-30-2009, 02:54 PM
impstrz28's Avatar
thanks. i think i want to leave the spark plug in so nothing goes in there. the exhaust valve is still good so i shoulnt get that effect right?
Old 08-30-2009, 07:14 PM
ss.slp.ls1's Avatar
Did you check the pushrod associated with that rocker arm for straightness?
Old 08-31-2009, 10:15 AM
SP Motorsports's Avatar
if you pull the rocker arm off and run it you will need to pull the spark plug allso.but it should last.you will still most likely burn the ring out of it driving it for that long.
Old 08-31-2009, 12:38 PM
Wicked_muscle's Avatar
I wouldn't personally do it but I have several dd options. Just get it done so you don't have do add RIP next to the Camaro too.
Old 08-31-2009, 03:00 PM
impstrz28's Avatar
looks straight.
Old 08-31-2009, 03:02 PM
impstrz28's Avatar
i am just going to take it all apart. ill take pictures as i go and might ask some questions.
i got a dd now its a 1980's ten speed bicycle that i borrowed from a friend.
Old 08-31-2009, 06:10 PM
Ryphraph's Avatar
Might be good idea to uplug the injector so it doesn't get fuel in that cylinder.
*EDIT looks like you had that down in the original post...*
Ryph
Last edited by Ryphraph; 08-31-2009 at 06:12 PM. Reason: Finally read original post all the way...
Quick Reply: help!
