Western Members CA, AZ, NV, UT, CO, NM, HI
cooling system flush
Old 11-24-2009, 05:22 PM
allblacksrt4's Avatar
Default cooling system flush
anyone know of a good place that does cooling system flush. My Radiator took a crap and i have tranny fluid in the system that i cant get out. Anyone work at a place or know of anyone reliable to go to.
Old 11-24-2009, 05:26 PM
ss.slp.ls1's Avatar
Good thing you didn't get coolant inside the trans, lol.
Did you remove the (2) engine drain plugs to completely drain the engine block?
You could try removing your thermostat and run a hose to your water pump while the engine is running.
Old 11-24-2009, 07:03 PM
hitmanws6's Avatar
anyone at my work (sears) can do it for you.
Old 11-24-2009, 07:06 PM
180ls1's Avatar
Watch who you take it to, i know a shop who just opens up the radiator and then runs hose water through it then replaces the coolent. It is not worth what they charge.
Old 11-24-2009, 07:45 PM
hitmanws6's Avatar
we cycle new coolant through the system and suck out all the old with a machine, takes no more than 30 minutes
Old 11-25-2009, 09:38 AM
yea tried flushing it myself but its still pretty nasty.
Old 11-25-2009, 10:49 AM
ss.slp.ls1's Avatar
Did you actually remove the two allen screw drain plugs (one on each side of the block)?
Old 11-25-2009, 01:19 PM
yep it just nasty gunked up. just the water with the hose doesnt wash it out really.
Old 11-25-2009, 01:23 PM
ae13291's Avatar
maybe those super radiator flush chemicals? kinda sucks to get the oil residue out from the cooling system
Old 11-25-2009, 01:50 PM
carbonfiberbird's Avatar
+1 We use a chemical(I forget the name of it) but it works way better than just a straight flush.
Old 11-30-2009, 01:51 AM
ws6manny's Avatar
Rose Auto Repair
Yorba Linda, CA 92886
They know these cars very well and can handle all your repair needs. I think they have a website too.
Old 11-30-2009, 09:32 AM
XpEdItIoUs's Avatar
Do you really think pouring water in a block contaminated with trans fluid with get it out? I sure hope you know water and oil don't mix.
You can have a shop use a flush machine with an additive that will break down gunk and petroleum-based fluids.
Quick Reply: cooling system flush
