Western Members CA, AZ, NV, UT, CO, NM, HI
Local Tech for 02 Camaro
Old 09-19-2011, 02:10 PM
2002BulletZ28's Avatar
Default Local Tech for 02 Camaro
Anyone close to Huntington Beach??
Thanks,
Old 09-19-2011, 02:33 PM
ConElite's Avatar
what are you looking for? Kinda confusing.
Old 09-19-2011, 05:52 PM
Sorry!
Engine related item. some diagnostics for leak down/compression to start with.
Burning/Losing some oil and now starting to get oil gauge bouncing around.
Thanks,
Old 09-19-2011, 09:00 PM
mannyman84's Avatar
Ls1's burn oil. A lot. All the ones I've had and my friends and other people I know with ls1's burn oil. And needle bouncing might be the pressure switch going out.
Old 09-19-2011, 09:03 PM
mannyman84's Avatar
Also depends how much you are burning. Is it constantly that u have to add oil?
Old 09-19-2011, 09:29 PM
NOS LS1's Avatar
Early LS engines burn the most oil & they have the notorious piston slap when cold.
Engineers at GM changed the PCV Design on later LS1 engines & this Decreased Oil Comsumption on Later LS1 engines.
The guys at Competition GT in Costa mesa are way cool & they can diagnois your Gauge problem very quickly. They would probably attach a mechanical oil pressure gauge to your block & check your Oil pressure. You might have a bad sending unit or a bad gauge. Worst case it could be your oil pump. I would not drive the car until you get it checked out. You dont wanna damage your engine.
The guys at Comp GT Do Awesome work & Tuning. They have a great Dyno.
Heres the Link... http://www.competitiongt.com/
Old 10-03-2011, 09:26 AM
Thanks Guys! I will look into Comp GT
Old 10-03-2011, 02:09 PM
LS1Adam84's Avatar
LS1's are known to use at least a quart of oil every 3k miles, some burn oil quicker and some slower, you may be losing some oil past the valve seals. The gauge bouncing around, how so? When you idle do you see at least 20 psi? Does the gauge read higher than 80 psi when wide open throttle?
Old 10-03-2011, 10:49 PM
emenny81's Avatar
Really good work at comp GT, had sub frame, torque arms, pan hard bar, CME and had the car re tuned to get my idle problem fixed.
definitely recommend them....
Old 10-04-2011, 03:42 PM
mannyman84's Avatar
You're welcome to come to my shop. If interested PM me. Check out our reviews on yelp aswell
mannyman84's Avatar
Located In harbor city
Old 10-11-2011, 05:29 PM
88vertSC's Avatar
Hit up Gene Jones Racing - 714 650 0042. They're in La Habra - straight shot up beach to imperial. If its fbody, you go to Gene. VERY reasonable on the prices and the work is second to none.
