Western Members CA, AZ, NV, UT, CO, NM, HI
295/40/17 Will They Fit?
Old 02-11-2012, 01:54 PM
HoosierDaddy?'s Avatar
Default 295/40/17 Will They Fit?
I have 275/40/17's now but have a set of mt 295/40/17 Will They Fit the Stock SS 10-Spoke rims??Any Rubbing? I hav no suspension work,cars at stock height.
Old 02-11-2012, 02:53 PM
MJs1FastSS's Avatar
i wouldnt go 295 on a 9" rim 275 i think is the biggest i'd ever go unless it was a bigger nitto tire since they run small to begin with. 9" width with bigger tires lead to poor wear, poor bead fitment and the strain applied to sidewalls that can lead to failure over time. You wont have rubbing issues.
Old 02-11-2012, 03:35 PM
99Bluz28's Avatar
IMO, I'd stick with what the manufacture recommends, if you want optimum performance out of your tires.
Old 02-11-2012, 08:58 PM
Burken01's Avatar
LS1Tech 10 Year
yes ive seen nitto 315's on a Zr1 rim, wonder why they run so small?
Old 02-12-2012, 03:49 AM
Blk98Vert's Avatar
They recommend 9.5 minimum, I wouldnt do it with something like DRs
Old 02-12-2012, 11:16 AM
ConElite's Avatar
yeah thats kinda wide of a tire for that rim.
Old 02-12-2012, 01:02 PM
Anybody have a set of 275/40/17's prefferably mickey thompsons?
Old 02-12-2012, 01:06 PM
baalic's Avatar
I have 285 nitto's on mine and they almost look stock. So far Im super happy and not seeing any negatives from the wider tire. Only just barely has any buldge compared to the stock size in front. To me the 275's nittos seem to run wide, and the 285's just feel right in the rear.
Old 02-12-2012, 02:27 PM
ZexGX's Avatar
It's a 26.3" tire vs. stock of 25.7" so it'll throw your gearing/speedometer off a bit.
Old 02-12-2012, 11:10 PM
ur jlus's Avatar
I run a 285/40/17 on my wear without any problems and that's with a pro-kit set of springs.
Quick Reply: 295/40/17 Will They Fit?
