If I won the Lottery !
Garage full of these, build a track, invite friends to have some fun.
http://www.youtube.com/watch?feature...v=CPinMa_0mPg#!
LS6/T56/8.8 rear in my miata.
Maybe even get one of the new Subaru BRZ cars to swap an LSx into. That would **** off the rice boys.
Nelson TT454/built 4L80e/Dana 60 in my SS.
Then I would buy a CTS-V Caddy wagon to DD, toss on a pulley/intake/tune and call it a day.
This Twin charged Lotus would be pretty awesome.
My last entry into my dream garage ^^ ! It would definitely be a great race, check the spec of the Venom GT ! Roughly 1057whp @ 2743lbs stock.
0 – 200 mph15.3 sec. (Bugatti Veyron = 24.2 sec.)
0 – 60 mph 2.5 sec.
Power
Power / Weight1244bhp / 1244kilograms (1bhp / 2.20 lbs)
Horsepower Adjustable with 3 settings: 800 bhp, 1,000 bhp & 1,244 bhp
Engine
Type V8
Block Aluminum
Size 427 CID (7.0 Liter)
Position Mid Longitudinal
Compression 9.2:1
Redline 7,200 rpm
Forced Induction Twin Garrett Ball Bearing Turbochargers
Oiling System Dry Sump Lubrication
Fuel System Sequential Multi-Port Electronic Fuel Injection
Transmission
Type Ricardo 6-Speed Manual
Gear Ratios 2.61:1, 1.71:1, 1.23:1, 0.94:1, 0.77:1, 0.63:1
Final Drive 3.36:1
Brakes
Calipers Brembo 6-Piston (all four corners)
Rotors 15.0 x 1.34 in. Carbon Ceramic (all four corners)
Suspension
Type Penske Adjustable Coilover (all four corners)
Ride Height Adjustable by 2.4 inches (60 mm)
Dimensions
Length 15.27 ft. (4,655 mm)
Width 6.43 ft. (1,960 mm)
Wheelbase 110.24 in. (2,800 mm)
Track – Front 63.46 in. (1,612 mm)
Track – Rear 63.15 in. (1,604 mm)
Body
Material Carbon fiber composite except doors & roof
Type 2-door
Weights & Measures
Curb Weight 2,743 lbs (1,244 kilograms)
F / R Balance 37 / 63 (empty); 44 / 56 (with driver & passenger)
Fuel Capacity 18.5 gal. (70 Liter)
0 – 60 mph 2.5 sec.
Power
Engine
Type V8
Block Aluminum
Compression 9.2:1
Redline 7,200 rpm
Transmission
Final Drive 3.36:1
Brakes
Suspension
Dimensions
Body
Type 2-door
Weights & Measures
