Western Members CA, AZ, NV, UT, CO, NM, HI
Help With Hooker Smog Headers - California
Old 09-18-2012, 11:33 PM
1997 Z71's Avatar
Default Help With Hooker Smog Headers - California
First, THIS IS A TEMP MOD. PLEASE DO NOT MAKE FUN OF ME FOR TAKING MY CAR BACK TO STOCK. RAN AN 11.9 @ 117 WITH THE OLD MOTOR AND WILL DO BETTER WHEN THE GOOD MOTOR IS REBUILT. BTW ITS ONLY A DAILY DRIVER.
I have a set of smog legal Hooker Headers for my 1994 Pontiac Firebird. The part number is 2062-HKR on the headers. On the Hooker/Holley webpage, these headers are 50 state emission compliant. They have a CARB number E.O. # D-164-5.
These headers were purchased in Michigan many years ago.
I live in California and the smog station will not inspect without the Carb number attached to the headers or a CARB sticker. I have neither. My good motor finally spun a bearing, so I have a stock motor that I am installing in and attempt to smog the car.
I called Hooker over 4 weeks ago, gave them all my info and they said they would send out a sticker. No sticker arrived. I called Hooker back yesterday and this time the person I talked to said that they do not have stickers for there headers. They stated that the carb number is attacked to the header. I can't find anything. The only tag is on one of the headers that states "Hooker Super Competition".
Called the Smog Referee Tech in Bakersfield and he said it has to have the CARB number.
Not sure what to do next.
Does anybody have a sticker or if they have a picture of the CARB number on the tubes, can you send me a picture so I can fabricate one.
Currently, I have the new stock motor on the K Member and ready to go in, but I need to get this smog **** figured out.
Also posted in the LT1 Section
Thanks
Attached Thumbnails Help With Hooker Smog Headers - California-dscn1087-1-1024x768-.jpg   Help With Hooker Smog Headers - California-dscn1081-1-1024x768-.jpg   Help With Hooker Smog Headers - California-dscn1057-1-1024x768-1024x768-.jpg
Old 09-19-2012, 09:27 AM
LS1TECH Sponsor
Ryne @ CMS's Avatar
I have a set of smog legal Hooker Headers for my 1994 Pontiac Firebird. The part number is 2062-HKR on the headers. On the Hooker/Holley webpage, these headers are 50 state emission compliant. They have a CARB number E.O. # D-164-4.
Thanks
i had this happen years ago to my 93 TA... i had a set of borla shorties on it and the Carb# plate thast was tacked on fell off.... i ended having to get a copy of the paperwork that carb sent to borla stating that this Pt# header on these year cars carries X carb number... once i gave that to the smog tech they smogged the car... i would call hooker and see if you can get that info, or maybe you can get it from carb
Old 09-19-2012, 01:02 PM
1997 Z71's Avatar
Can somebody with a set of these headers or Hooker Smog headers in general send me a picture of the CARB number plate welded to the tubes?
I called Hooker again today and they stated that it should have a square plate on the drivers side header. They tried telling me that I probably did not have smog headers. The part number on the inside flange is right on the Holley/Hooker website showing 50 state emission legal with a CARB number. After explaining that I am not lying to them they said that if the tag is no longer on that I should buy a new set of headers. WTF
I am trying to do it right, why is it so difficult.
Any help greatly appreciated.
PDF of product sheet from Hooker below.
File Type: pdf
Old 09-19-2012, 01:35 PM
KILLER-LS1's Avatar
This is the Carb E.O. PDF
http://arb.ca.gov/msprog/aftermkt/de...eo/D-164-5.pdf
Old 09-19-2012, 01:39 PM
KILLER-LS1's Avatar
EO: D-164-5 View PDF
EO Date: 1998-11-30
Manufacturer Name: Hooker Industries, Inc.
Device: Super Competition Exhaust Headers
Device Type: Exhaust System / Exhaust Modification
Part_Number: Model_Specification: Modification_Allowed: Remarks:
2017 1996-1998 Chevrolet/GMC PU 1500, 1996-1998 Chevrolet Suburban 1500, 4WD w/o A.I.R. Single Cat., 350 Header and connector/Y-pipe assembly
2018 1996-1998 Chevrolet/GMC PU 1500, 1996-1998 Chevrolet Suburban 1500, 2WD w/o A.I.R. Single Cat., 350 Header and connector/Y-pipe assembly
2019 1996-1998 Chevrolet/GMC PU 1500, 4WD C.P.I. w/o A.I.R., 4.3L V6 Header and connector/Y-pipe assembly
2020 1996-1998 Chevrolet/GMC PU 1500, 2WD C.P.I. w/o A.I.R., 4.3L V6 Header and connector/Y-pipe assembly
2021 1996-1998 Chevrolet/GMC PU 2500/3500, 1996-1998 Chevrolet Suburban 2500, 4WD C.P.I. w/ A.I.R. Dual Cat., 7.4L V8 Header and connector/Y-pipe assembly
2022 1996-1998 Chevrolet/GMC PU 2500/3500, 1996-1998 Chevrolet Suburban 2500, 2WD C.P.I. w/ A.I.R. Dual Cat., 7.4L V8 Header and connector/Y-pipe assembly
2023 1996-1998 Chevrolet/GMC PU 2500/3500, 1996-1998 Chevrolet Suburban 2500, 4WD C.P.I. w/o A.I.R. Dual Cat., 350 Header and connector/Y-pipe assembly
2024 1996-1998 Chevrolet/GMC PU 2500/3500, 1996-1998 Chevrolet Suburban 2500, 2WD C.P.I. w/o A.I.R. Dual Cat., 350 Header and connector/Y-pipe assembly
2025 1996-1998 Chevrolet/GMC Full Size Tahoe/Yukon, 1996-1998 Chevrolet/GMC PU 1500, 1996-1998 Chevrolet Suburban 1500, 4WD w/o A.I.R. Dual Cat., 350 Header and connector/Y-pipe assembly
2026 1996-1998 Chevrolet/GMC Full Size Tahoe/Yukon, 1996-1998 Chevrolet/GMC PU 1500, 1996-1998 Chevrolet Suburban 1500, 2WD w/o A.I.R. Dual Cat., 350 Header and connector/Y-pipe assembly
2027 1996-1998 Chevrolet/GMC PU S-10/S-15/Sonoma, 2WD C.P.I., 4.3L V6 Header and connector/Y-pipe assembly
2028 1996-1998 Chevrolet/GMC Blazer/Jimmy/S-10/S-15/Sonoma, 4WD C.P.I., 4.3L V6 Header and connector/Y-pipe assembly
2029 1996-1998 Chevrolet/GMC S-Series Blazer/Jimmy, 2WD C.P.I., 4.3L V6 Header and connector/Y-pipe assembly
2030 1988-1995 Chevrolet/GMC PU 1500/2500, 4WD T.B.I. w/o A.I.R., 4.3L V6 Header and connector/Y-pipe assembly
2031 1988-1995 Chevrolet/GMC PU 1500/2500, 4WD T.B.I. w/ A.I.R., 4.3L V6 Header and connector/Y-pipe assembly
2032 1988-1995 Chevrolet/GMC PU 1500/2500, 2WD T.B.I. w/ A.I.R., 4.3L V6 Header and connector/Y-pipe assembly
2033 1988-1995 Chevrolet/GMC PU 1500/2500, 2WD T.B.I. w/o A.I.R., 4.3L V6 Header and connector/Y-pipe assembly
2034 1981-1986 Chevrolet/GMC PU K-10(1/2) K-20(3/4), 4WD w/ Carb w/ A.I.R., 305-350 Header and connector/Y-pipe assembly
2035 1981-1987 Chevrolet/GMC PU C-10(1/2) C-20(3/4), 2WD w/ Carb w/ A.I.R., 305-350 Header and connector/Y-pipe assembly
2036 1988-1995 Chevrolet/GMC PU 2500/3500, 1992-1995 Chevrolet/GMC Crew Cab 3500 4 door, 4WD T.B.I. w/o A.I.R., 7.4L Header and connector/Y-pipe assembly
2037 1988-1995 Chevrolet/GMC PU 2500/3500, 1992-1995 Chevrolet/GMC Crew Cab 3500 4 door, 2WD T.B.I. w/o A.I.R., 7.4L Header and connector/Y-pipe assembly
2038 1988-1995 Chevrolet/GMC PU 2500/3500, 1992-1995 Chevrolet/GMC Crew Cab 3500 4 door, 4WD T.B.I. w/ A.I.R., 7.4L Header and connector/Y-pipe assembly
2039 1983-1986 Chevrolet/GMC Full Size Blazer/Jimmy, 4WD w/ Carb w/ A.I.R., 305-350 Header and connector/Y-pipe assembly
2040 1983-1986 Chevrolet/GMC Full Size Blazer/Jimmy, 2WD w/ Carb w/ A.I.R., 305-350 Header and connector/Y-pipe assembly
2041 1987-1991 Chevrolet/GMC Full Size Blazer/Jimmy, 4WD T.B.I. w/ A.I.R., 305-350 Header and connector/Y-pipe assembly
2042 1992-1995 Chevrolet/GMC Full Size Blazer/Jimmy/Yukon/Tahoe, 1988-1995 Chevrolet/GMC PU 1500/2500, 1992-1995 Chevrolet Suburban 1500/2500, 4WD T.B.I. w/ A.I.R., 305-350 Header and connector/Y-pipe assembly
2043 1988-1995 Chevrolet/GMC PU S-10/S-15/Sonoma, 2WD T.B.I./C.P.I., 4.3L V6 Header and connector/Y-pipe assembly
2044 1986-1993 Chevrolet/GMC PU S-10/S-15, 2WD T.B.I. 2 1/4" Inlet Slip-on Cat., 2.8L V6 Header and connector/Y-pipe assembly
2045 1983-1985 Chevrolet/GMC PU S-10/S-15, 2WD w/Carb, 2.8L V6 Header and connector/Y-pipe assembly
2046 1986-1993 Chevrolet/GMC S-Series Blazer/Jimmy, 2WD T.B.I. 2 1/4" Inlet Slip-on Cat., 2.8L V6 Header and connector/Y-pipe assembly
2047 1983-1985 Chevrolet/GMC S-Series Blazer/Jimmy, 2WD w/Carb, 2.8L V6 Header and connector/Y-pipe assembly
2048 1991-1992 Chevrolet Camaro IROC Z-28, 1991-1992 Pontiac Firebird Trans Am and Formula, T.B.I. w/ 2 1/4" Inlet Slip-on Cat., 305 Header and connector/Y-pipe assembly
2049 1983-1988 Chevrolet Monte Carlo, 1983-1988 Chevrolet El Camino, Non H.O. 2 1/4" Inlet Slip-on Cat., 305 LG-4 Header and connector/Y-pipe assembly
2050 1983-1988 Chevrolet Monte Carlo, 1983-1988 Chevrolet El Camino, H.O. 4-Bolt Cat., 305 L-69 Header and connector/Y-pipe assembly
2051 1982-1987 Chevrolet Camaro, 1982-1987 Pontiac Firebird, 2 1/4" Inlet Slip-on Cat., 305 LG-4 Header and connector/Y-pipe assembly
2052 1983-1986 Chevrolet Camaro, 1983-1986 Pontiac Firebird, H.O. 4-bbl Carb. 4-Bolt Cat., 305 Header and connector/Y-pipe assembly
2053 1985 Chevrolet Camaro IROC, 1985 Pontiac Firebird Formula, T.B.I. 4-Bolt Cat., 305-350 Header and connector/Y-pipe assembly
2054 1988-1992 Chevrolet Camaro RS, 1988-1992 Pontiac Firebird Formula, T.B.I. 2 1/4" Inlet Slip-on Cat., 305 Header and connector/Y-pipe assembly
2055 1986-1990 Chevrolet Camaro IROC Z-28, 1986-1990 Pontiac Firebird Formula, T.B.I. 3" Inlet Slip-on Cat., 305-350 Header and connector/Y-pipe assembly
2056 1989-1992 Chevrolet Camaro, 1989-1992 Pontiac Firebird, T.P.I. Dual Cat., 305-350 Header and connector/Y-pipe assembly
2057 1988-1995 Chevrolet/GMC PU S-10/S-15/Sonoma, 4WD T.B.I./C.P.I., 4.3L V6 Header and connector/Y-pipe assembly
2060 1993 Chevrolet Camaro Z-28, T.P.I. w/ Single Cat., 350 LT-1 Header and connector/Y-pipe assembly
2061 1992-1995 Chevrolet Corvette, T.P.I.w/ A.I.R., 350 LT-1 Header only
2062 1994-1995 Chevrolet Camaro Z-28, T.P.I. w/ Single Cat., 350 LT-1 Header and connector/Y-pipe assembly
Old 09-19-2012, 01:40 PM
KILLER-LS1's Avatar
it shows your part number on the Carb site, but not on the PDF... Weird.
KILLER-LS1's Avatar
This is where i got the PDF:
http://www.arb.ca.gov/msprog/aftermk...Search+for+EOs
Old 09-19-2012, 06:34 PM
1997 Z71's Avatar
I found in the Bar Manual, " In cases where the label is missing or illegible, the technician my proceed with the inspection, provided the parts can be confirmed as CARB approved or exempted by comparing the part number marked on the part with the CARB EO parts listing or the parts manufactor catalog."
I'm going to take this to my smog guy and see if he will work with me.
If not, any pictures of the carb plaque on a set of Hooker Headers is greatly appreciated.
Old 09-29-2012, 10:56 AM
98TAjwh's Avatar
check your other thread. you don't have to have the sticker.
Quick Reply: Help With Hooker Smog Headers - California
