94 Camaro w/2003 6.0L LQ4 motor
I have my eye on a nova so my camaro needs to go bye bye.
1994 Camaro Z28 (6.0 Liter)
Engine:
2003 6.0L LQ4 truck engine (iron block) with about 30k miles !!!
Stock 317 Alum Heads
Ported TB, descreened MAF, cut EGR tube
LS1 Intake
186* Thermostat
K&N Filter
255lph Fuel Pump
30lb per/hr Injectors
10w 30 Synthetic Oil Only
2002 PCM
Tuned with 'HP Tuners' by George Lara at http://www.JenibellaRacing.com
Transmission:
Built 4L60e Auto Trans (Less than 600 miles since built)
Yank SS 4200 Stall Converter with lock-up
Shift Kit
Billet Servo's
Kevlar Band
Alto Clutches
Sun Shell
TCI Trans Cooler
Rearend:
10-Bolt rear with 2.73 gears and Trackloc Posi
Exhaust:
Hooker Shorty smog-legal Headers into 3" y-pipe then Bung welded-in after y-pipe so it's ready for your Wideband Air/Fuel o2 sensor, then goes into NEW single 3-way Cat then into huge 4" pipe & Muffler (rear o2's deleted). Sounds Awesome!!!!
Suspension:
QA1 (R's) 12 way adj. Coil Over 90-10 Drag Shocks up front with Eibach Drag Launch Springs
KYB AGX 8-Way adj. shocks in rear
Spohn adjustable Rear Lower Control Arms
Spohn adjustable Torque Arm with Driveshaft Safety Loop
Front swaybar dissconnected & Rear swaybar connected
Poly Bushings
Subframe Connectors
Tires / Wheels:
16x8 Wheels & Toyo 245-50/16 tires all the way around (excellent tread)
Other info:
1997 30th Anniversary grey cloth front seats
Harwood Black Fiberglass Cowl Hood (uses OEM hinges and latch assembly, so it works just like a stock hood)
AM-FM CD player
Power Steering
Power Brakes
Power Windows
Power Door Locks
Power Mirrors
No A/C, Heater, ABS or Traction Control
Jegs Linelock
CLEAN CALIFORNIA TITLE IN MY NAME. Adult owned, not abused. Speedo shows about 124k miles
Best 1/8 mile time at Irwindale on ET Streets is: 7.80 @ 87.42 mph & 1.69 60ft. The car launches very hard.
Passes CALIF Smog, legally. I will include a smog cert.
For more info call: 626-347-0713
Located in Monrovia, CA 91016
$7500
New price---- $6800
Newer price >>>> $6500
More pics here
Engine:
LS1 Intake
186* Thermostat
K&N Filter
255lph Fuel Pump
2002 PCM
Transmission:
Shift Kit
Billet Servo's
Kevlar Band
Alto Clutches
Sun Shell
TCI Trans Cooler
Rearend:
Exhaust:
Suspension:
Poly Bushings
Subframe Connectors
Tires / Wheels:
Other info:
AM-FM CD player
Power Steering
Power Brakes
Power Windows
Power Door Locks
Power Mirrors
Jegs Linelock
$7500
New price---- $6800
More pics here
Originally Posted by Ryne @ CMS
who built the trans? and interested in any trades?
Price lowered to $6800 - I need to get it out of my driveway.
Originally Posted by 408Maro
any estimate on hp?
No sorry, I have a bad back. I feel like I am 85
Originally Posted by Ryphraph
Are you going to have it out at Irwindale tonight? I am trying to get a buddy interested.
Ryph
Ryph
