What Clutch & Flywheel to get
Im thinking of getting a spec stage 3 but not sure what kind of flywheel to get. Is it worth getting aluminum, or just go with billet. Ive seen some cheap flywheels on ebay but dont know if I should go with that.Want to order it before the wife changes her mind. help me out
Mods are:headers, x-pipe, lid, Throttle body
Planing on cam and nitrous
Ls7 clutch with ls2 flywheel would probably be the best. Would keep the driveability and be able to handle the power you'll be putting to it. 400 @ sdparts.com You can check out the manual section... lots of advice there.
I have the LuK Progold clutch on my Camaro, and could not be happier. It is not the MOST performance minded clutch around, but if you want a bullet proof one, this is the way to go. I have talked to a lot of other people that have them, and no one has had problems. Much better than my stock one that I had.
HERES WHAT I MIGHT GO WITH ON THE CLUTCH http://store.summitracing.com/partde...5&autoview=sku AND HERES THE MASTER CYLINDER http://store.summitracing.com/partde...5&autoview=sku YOU WILL ALSO NEED THE SLAVE CYLINDER & THROW OUT BEARING !
Take a look at the Textralia, especially if going the nitrous route. With the amount of torque nitrous produces you need a good clutch.
I have the OZ700 Z-grip with the steel billet flywheel and I'm putting out over 600+ rwtq. No problems holding it plus very good street manners.
Good luck.
Good luck.
I'd like to know a little more about the textrelia clutches... I've got a Clutchmasters Stg.III and Aluminum Flywheel... unfortunately I have not been able to find a person that knows how to install a clutch worth a damn and I haven't really been able to enjoy it so much... when it was installed correctly though, I liked it a lot. I know a guy with a twin turbo camaro pushing over 600hp that swears by em...
