Western Members CA, AZ, NV, UT, CO, NM, HI
Engine wont start it might just have taken a sh...
Old 06-20-2008, 09:48 PM
633997's Avatar
Default Engine wont start it might just have taken a sh...
I think my engines seen better days, its got 186,XXX miles. Wont start, electrical system is good. Anyone got any recomendations on were I should take my car to get it looked at locally preferrably in the san gabrial valley? Perhaps someone who's got some knowledge on lt1's?
Old 06-20-2008, 11:32 PM
ss.slp.ls1's Avatar
I'm pretty knowledgeable with LT1's.
Old 06-20-2008, 11:39 PM
XpEdItIoUs's Avatar
Dose it crank? Or dose it feel like it's seized?
Old 06-21-2008, 02:10 PM
93Z28rare's Avatar
I know of a place in El Sereno close to Alhambra that could take a look at it. PM me for details.
Carlos
Old 06-21-2008, 02:13 PM
BackInBlack02's Avatar
if you already checked for spark, check for fuel, you can check for pressure at the fuel rails.
Old 06-21-2008, 02:18 PM
180ls1's Avatar
Pull out a spark plug (still attached to wire) and ground to something like your echaust manifold and then turn the car over and see if you can get a spark. That will determine if it is spark related. Also pull yout intake off just before your your maf and spray starter fluid in there and then turn it over. See if that helps those are both super easy ways to check for fuel and spark problems.
Old 06-21-2008, 02:57 PM
6LITEREATER's Avatar
Explain further "won't crank" maybe we can help...
Old 06-21-2008, 05:01 PM
Dan
Dan's Avatar
could be just the opti that went bad
Old 06-21-2008, 06:44 PM
ss.slp.ls1's Avatar
I've replaced the plugs, wires, coil, opti, and fuel pump on my 97 SS. I've pretty much been through it all when it comes to a LT1. Depending on where you are located, I can help you out.
