1998 SS Racecar, 408", N/A 500+ RWHP, N2O car
Old 12-23-2008, 04:08 PM
98CamZ28's Avatar
Default 1998 SS Racecar, 408", N/A 500+ RWHP, N2O car
This is fun I'll probably consider selling this car in the spring unless someone offered a decent penny for it. Let me know what you guys think
98 SS
BODY/INTERIOR
1998 Camaro SS
-White
-T-Tops
-Nice body and paint
-clean title
-RCI 5 point Camlock safety harness
-2 Kirkey aluminum drag racing seat
-Autometer Sport comp Tach
-Autometer Ultralite Water/Oil gauges
-Grant steering wheel with Grant quick release hub
-Hurst Pistol Grip Quarter stick shifter
-Battery relocated to rear with custom sealed box, Flaming river On/Off switch
-Interior is complete.(as in all panels, no metal showing)
Vehicle has been lightened. All A/C and Heat removed, no stereo or speakers, bumper supports etc.
ENGINE/TRANSMISSION
-410ci Iron LS1 stroker by LME
-12.0:1 compression
-Callies Dragon slayer 4.00" stroke crank
-Lunati 6.125 Pro-Billet rods
-ARP main studs
-ARP head studs
-Fel-Pro custom head gaskets
-Custon Nitrous rings
-Cam Motion custom grind billet nitrous camshaft (awesome sound).640 lift
-EXTENSIVELY ported LS1 (241) Stage 3 cylinder heads. Almost 340cfm@.650. Stainless valves, etc. Only the best components used. Over $3800 invested in cyl. heads alone.
-Kooks Stainless 1-7/8" to 2" to 3.5" collector
-Edelbrock Victor Jr intake ported
-Custom fabricated aluminum intake elbow
-Custom 4” Stainless cold air intake out the front
-Accufab 105mm polished throttle body
-ASP pulley
-TRANZ-KING Full race built Turbo 400 w/pro tree trans brake
-Circle D 3600/3800 converter
-B&M heavy duty transcooler with all braided line
-TCI SFI flexplate
-C&T custom driveshaft
-MOSER Ford 9" rear end
-Pro series spool
-custom axles with large 5/8" wheel studs installed
-3.90 gear
-Nodular iron center section with aluminum pinion support
-Header evac setup
-New ls7 lifters and trays
-New slp oil pump
-Most new sensors
NITROUS
-NOS Fogger with Pro race nitrous solenoids, dual purges,
-Standalone 1 gallon cell in front w/holley blue pump
-Timing tuner
-Engine harness converted from 98 to 99+ with pcm
-SD Tune
SUSPENSION/CHASSIS
-Full 25.5 chromoly cage
-BMR k-member/stock control arms
-QA1 "R-series" coil over front shocks
-QA1 rear adjustable drag shocks
-LCA relocation brackets
-BMR Extreme duty torque arm
-BMR Extreme duty rear anti-roll bar
-BADZ Adjustable chromoly rear lower control arms
-BADZ Components panhard ron
-Weld Drag Lite 15x10 rear with MT 28x10.5W slicks
-Weld Drag Lite front wheels with Hoosier front racing tires
-4” Glasstek bolt on hood
Car was dynoed by Speed Inc. and put down 518rwhp at 7000rpm. The car has 1 timed shake down N/A run where it ran 10.601 @ 126.8 with a 1.45 60ft but the car was beginning to get hot from a fan issue that was resolved and an oil leakage issue that has been resolved. This run was also without a tach. I would venture to guess this car should go 10.4’s easy on motor, hopefully quicker. The engine was built to handle a 400 shot of spray. I believe on a 300 shot she will probably see high 8’s as that is what she was designed to do but hope to see that on a 250 shot here in the spring. I believe that if an exhaust setup was installed, that you could drive her on the road. This engine has not seen n2o yet, but it’s coming soon
Here are a bunch of pics and a few vids. Some of the vids are from when we had our track timing system stolen (crazy, I know) so I don’t know the times from the.
Vids in Next post
Old 12-23-2008, 04:09 PM
98CamZ28's Avatar
Vids
Latest vid – idle clip
10.60 run
Couple other vids
Click here to watch Last-Launch
Click here to watch Me-vs-Bike
Accidently shift 1-3
Click here to watch 1st-runtune
Old 12-27-2008, 05:40 AM
98CamZ28's Avatar
Damn, no one wants to guess? I thought this would be fun but, I guess not
Old 12-28-2008, 07:36 PM
boosted4life's Avatar
damn man that is a sick *** car. I would pick it up right now cash but i really have no idea what you would want and im willing to bet its more than i have..
Old 12-28-2008, 07:45 PM
cbra-klla's Avatar
25.5 doesnt come cheap...if i had rid of my car, i would buy it tommorrow..why you selling it??
Old 12-29-2008, 10:19 AM
98CamZ28's Avatar
Thanks guys for the responses, just became a little more fun
I'm thinking about selling it next year b/c that i'm thinking about buying a house and this would be a nice help towards a down payment. I've molded this car the way i've always wanted a car, want to do a few more small things and make an 8 second pass and then i'd let her go. I'd even not spray her if a potential new owner really wanted it.
About the 25.5, yea it definitely wasn't cheap, but what's nice is that I still retained the stock floor which made it much more difficult (I was there helping where I could with the cage builder). We made the cage all symmetric and pleasing to the eye as well
Old 12-29-2008, 09:04 PM
cbra-klla's Avatar
any idea on a price??
Old 12-29-2008, 09:06 PM
98CamZ28's Avatar
Eh, I just put it in the FS section for $25,500. I really don't wanna sell it but I would like to get a house here soon.
Old 01-03-2009, 07:36 PM
blubox's Avatar
That's the nastiest cage I've ever seen!
Old 01-04-2009, 08:31 PM
bigblock4-speed's Avatar
18-20k.. maybe.
Quick Reply: 1998 SS Racecar, 408", N/A 500+ RWHP, N2O car
