2001 Red TA Firehawk - $13K A Good Deal?
This is a repost and will try to shorten the reading in hopes of receiving more feedback. $13K for a 2001 Red Trans Am Firehawk with 54,000 miles - is it a good deal? I have not yet seen the car (other than pictures) or driven it yet. I understand the car was well taken cared of.
SLP Firehawk 17" chrome wheels
SLP Bilstein ultra performance suspension system w/re calibr Bilstein shocks
SLP Auburn high torque performance differential
SLP Revised Front End links & 1LE Panhard Bar
SLP 35mm Frt swaybar & 21mm rear swaybar
SLP High performance stall converter (2400-2600 stall)
SLP 3.73 ratio gear set
SLP Subframe connectors (bolt on/welded)
SLP Strut tower brace
SLP Tuned/Long tube headers & y-pipe
SLP header installation kit
SLP high flow catylitic converters
SLP TCS reversal module
SLP speed processor for 3.73 gear set
SLP high flow air box lid
SLP cold air induction kit
SLP MAF (85mm)
SLP 160 deg. low temp thermostat
SLP air temp module
Lakewood traction bars
Lakewood adjustable panhard bar
OEM replacement calipers (painted to match car)
Bear EradiSpeed+ slotted & cross drilled Zinc washed rotors (front & rear), Hawk high performance brake pads
Hypertech Power Programmer III
Traction Control
Custom Headrests w/Firehawk Emblem
Ebony Leather Seats
All original parts that were replaced by SLP parts are included. Any and all documentation also included. There is a scratch on the passenger door which doesn't look too bad from the picture I saw. Tires are about 70% good. Thanks for your feedback.
SLP MAF (85mm)
SLP air temp module
Traction Control
Ebony Leather Seats
CARFAX Report - Question to Forum
I have a question in regards to the CARFAX report - or more or less opinions. The CARFAX report is clean, one owner only. The question/concern I have is there is only one entry in regards to the car's maintenance history. That was at 19 miles when the car was first purchased. Since then no other posted maintenance reports, other then two entries from the state motor vehicle dept and two from the car dealership who is selling the car. The car has just over 54,000 miles. Any reason for concern/red flag? Thanks
it means that either the owner did any work himself or the shop that he took it to doesn't report to whatever database carfax uses. I don't believe the smaller shops report...but could be wrong.
http://www.firehawk.org/article/2498.html
1 of 83 in bright red.
1 of 32 with the A4.
This car is a GREAT buy at that price. Even it needs a little work its still got low miles for the year and it is a Firehawk.
Let's hope i get there (as a owner) and this car checks out okay - and I get it at the price range I want. I say that because they had a lower price on their dealership website. I asked to confirm before I drive out there. Then they claimed it was a wrong price, blaming it on a web software problem. Now it's listed at $15K.
Absolutely! If I walk in with a $13K cashier check, we'll see who's pocket the keys are in when I walk out.
That's one thing I'm waiting to find out - will it check out mechanically. They (dealership) installed a new battery and a new windshield. One problem I have is I have to drive almost 300 miles to go see it & not sure if I can find someone to check it out quick. I'm mainly worried about things like the cylinder compression and the tranny. They say the car was well taken care of and they can find nothing mechanically wrong with it. Like they would say if there really was. I'm hoping to go see it next Friday.
